lcd display
i have an lcd display very similar to your non-backlight 16x2 char. model. only problem is that it doesnt have the module on the back with the switches, contrast, and controller chip. is there any way to use this without the backpacked controller? chips on back of the display·are labled (left to right)·
..........................................R
.....5M5 1.................5L2
..HD44100H............HD44780A46
dots are for formatting only and arent on the chips
thank you,
nick
thank you,
nick
all electronics has an LCD ic that would work for you.
-Pat
Wulfden's kit - I have used this one and it works well. This is actually a PHAnderson kit I think.
Sparkfun - I have one of their serial LCDs that uses this, but haven't had a chance to try it out yet.
EDE chip at All Electronics - This is a pre-programmed PIC. Its the chip only, so it will not be as easy to use. You also need need a 4MHz resonator to go with it.
EDIT - I probably should add... If you or someone you know can program SX chips (you need an SX-Key or Blitz), there's an example in the SX-Key help file that will do what you want.
- Rick
Post Edited (RDL2004) : 4/18/2007 1:55:55 AM GMT
