Enclosure for BOE
I can't seem to locate a ready made solution for a enclosure box for the BOE.· I'm trying to finish a project up, and the instructer indicated he wants a neat, professional looking project.· So I want to put the unit in a box with the pot on the top and the LCD display showing.· I can cutout what I need but need to find a box, preferably with some kind of mounting for the size board the BOE is.· Any suggestions?
Russ
Russ
You can just use any enclosure that the BOE will fit inside and drill your own mounting holes to line up with the holes in the board then mount it on stand offs. Take care.
http://www.pactecenclosures.com/
I thought the "HP" series might work -- but to fit the BOE, you'll need an 'expander' ring to make the enclosure thicker.
It "would be nice" at some point if Parallax did a little research so they could have a definitive answer as to a nice enclosure for the BOE board.· I know that MOST people will use the board in a lab environment, but it would be good to know an off-the-shelf enclosure that fit the board -- or one of the really nice Parallax prototype boards that match the BOE mounting hole pattern.
Having said that, I must say that in the three years or so I've been using the BS2, the enclosure question has only come up three times or so.· And that 'research' I mention above could be quite time consuming -- there's hundreds of possible enclosures, only a few of which would work really well.
Post Edited (allanlane5) : 4/17/2007 7:20:51 PM GMT
My experience with putting projects into cases is that you want to err on the side of too big. For your project you may want to look at cases in the 6"x4"x2" range, maybe bigger, depending on which side gets the controls and LCD.
- Rick
We once had an enclosure in process that fit our 3x4 boards. We designed several tops for LCDs, pushbuttons and used cable glands for power supply. A DB-9 extension fit into the side of the project box.
The reason that they never made it to market is that most of our office was convinced that no matter what we designed, that our customers would not be happy. Everybody is very specific about the boxes they want to use, and it seemed like we'd sell too few to justify the cost of tooling. This was an all-AL box.
But I regret not finishing the project, between you and I. I should get it going and let our customers decide.
Thanks again, it would have been a nice addition to your line (in my thinking anyway).
Russ
Avoid a power drill when making holes in a plastic box. The high speed can create problems. I some cases the plastic will melt as you drill.
I use an old hand drill and I don't have problems with the bit drifting and skipping as I start the hole.
For really delicate work, I hold my drill bits in a 'pin vise' and drill entirely by hand. In fact, I use the pin vise to drill solder out of clogged circuit board holes by using a 0.1mm drill.
The results are much cleaner and I don't have to drag power cords and such around. It may seem counter-intuitive, but hand tools can actually do a better job with plastic.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
So, I urge you to not look to Parallax, nor in the electronics parts catalogs, but rather look·in the trash, in the electrical section of your hardware store, in the kitchen supplies section of your food market, and all other places where boxes are --lonely and feeling unwanted-- waiting for your imagination to put them to some really cool uses !
I wouldn't say that "It's not building the electronics, but finding the right box, that is the challenge", but you might :>)
PAR
The issue is not just a box that will fit the components, but a box that would give the look and feel of a finished product. While I'm sure I can fit it in a recycled tool container, it wouldn't give the polished finish I'm sure this instructor is looking for. I could also machine one out of solid aluminum if I had the time, but now I have 1-1/2 weeks left to finish it up so I don't think that even ordering it from DigiKey will do. I'll have to find something "pretty close" at Radio Shack. I usually have issues to fix once I finish something and plan on at least 2 days correcting my mistakes.. If only I was as perfect as I think I am..
Russ
PAR
I made my own box for the project I am currently working on.
·http://forums.parallax.com/showthread.php?p=641010
Fernando Gomez
revinc.us
gomez-rivera.com
Never compare yourself with anyone else, there will always be someone bigger·or·smaller·than you.
Russ
How about a picture of the finished bot with box?
Always looking for good ideas...
Whit+
No problem, almost done, probably another couple days and I'll have it completed. It's not a bot though, just a camera controller.
Russ
