If anyone has a BS1 Stamp please read last post in this thread.
I am working on a 2 wire device to interface with basic stamps using the shiftout and shiftin commands for error control. Basically the device receives data commands from a stamp in 8 bit bursts using shiftout. I use a timeout for the maximum time to wait from the first interrupt (start of the first bit out of the stamp) to the 8th bit. It defaults to allow sending 8 bits at a time. To send 16 bits I measure the time it takes to send 8 bits and then set the timeout to that plus a small amount. The device will automatically calibrate to any of the stamps that are faster than the BS2 but I need to know if my interrupt timer value can go high enough (higher is slower) to allow the BS1 to also use the device.
So specifically the bs2 I measure from the first clock rising signal to the last (8th) clock falling signal about 433uS
I need the time for this on the BS1
I guess I better find out the fastest stamp time as well. For this I will also need the low time between the 8th bit clock falling to the 9th bit rising signal for a 16bit shift.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Post Edited (metron9) : 4/18/2007 2:47:06 PM GMT
Ahhh i see the help file has the times for all the stamps.
Looks like it will work with an 8mhz internal oscillator even on the fastest stamp. I shall proceed. Thanks Mike
Could someone run this code (change it to run on the BS1 I don't have one) and tell me the maximum time from the first high to the last high signal on pin 1 (clock pin) by the way the extra HIGH 0 is in there to make the timing for both high and low almost the same. As long as $FF is longer then $00 for output it will sync to the data stream.
This bit banging takes 60mS on the BS2
' {$STAMP BS2} ' {$PBASIC 2.0} ' {$PORT COM2} OUTPUT 0 dbyte VAR Byte temp VAR Byte dbyte=255 'the byte to shift out GOSUB shifto END Shifto: temp=128 shiftolp IF dbyte & temp >0 THEN bithigh HIGH 1 LOW 1 LOW 0 DEBUG DEC temp,CR temp=temp/2 IF temp<>0 THEN shiftolp RETURN bithigh: HIGH 0 'extra command to make both high and low the same amount of time HIGH 0 HIGH 1 LOW 1 LOW 0 temp=temp/2 DEBUG DEC temp,CR IF temp<>0 THEN shiftolp RETURN▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
