I am programming a boe-bot using basic stamp and I don't know how to make it follow a white line. Does anyone have a code written up that they could offer me? I need it by next week. Thanks.
Line following in a week?· That sounds like some homework you can probably do without too much trouble...·
There are some examples for following black lines that you should study, and then, I think you'll find it pretty easy to write your own white line following code.
Here are examples of following a black line with the QTI sensors:
Also, there's an example of following a bold, black stripe in the Robotics with the Boe-Bot text. The code probably isn't very difficult to tweak for following a bold white stripe instead. See Chapter 8, Activity #3:
Of course, Robotics with the Boe-Bot is also a good primer.· Going through the activities in the text will really help you build your circuit and programming skills for the task at hand.
Andy Lindsay
Education Department
Post Edited (Andy Lindsay (Parallax)) : 4/17/2007 12:55:00 AM GMT
Simple: http://forums.parallax.com/forums/default.aspx?f=6&m=55290
Optimal: http://forums.parallax.com/forums/default.aspx?f=6&m=132921
http://www.parallax.com/dl/docs/books/edu/Roboticsv2_2.pdf
Andy Lindsay
