Problem with Repeat and floating point math.
Hi all,
I am trying to implement a·line drawing routine in spin but I am having trouble with the floating point stuff.
I am not having much luck, it's hard to explain but with my spin version·(below this c version) I can't get it to increment Y correctly.· It's·an integer/float·problem I think. The X and Y·are longs(?) and·a and b are floating point numbers. Ultimately I would, like do to it in assembly, but I need to understand what's going on first in spin.··
' C++ version: unknown author
void drawLineC(u_char x1, u_char y1, u_char x2, u_char y2, u_char color)
······· float a, b;
······· u_char x, y;
······· b = (float)((y2 - y1) + 1) / (float)((x2 - x1) + 1);
······· a = y1;
······· for(x = x1; x <= x2; x++)
··········· for(y = (u_char)a; y <= (u_char)(a + b); y++)
··············· if(y <= y2)
··················· GotoXY(x, y); // Goto start of fill area (Top Left)
··················· SendLcd(LCDCommand, RAMWR); //··· write to display
··················· SendLcd(LCDData, color);
··········· a += b;
'Spin·version: Was·testing using arguments: 50,50, 131,80
' kinda ugly, trying to get it to work.
·'fmath : "float32full"
·'flmath : "floatmath"
·'fstring : "FloatString"
pub drawLineSpin(x1,y1,x2,y2,color)| x,y,a,b
··· b := fmath.fdiv(fmath.ffloat((y2 - y1) + 1), fmath.ffloat((x2-x1) + 1) )···································································
··· a := y1·······················
··· 'some·'sysouts' for debugging
··· setxy(30,0)·
··· str(fstring.floattostring(b),0, black)
··· 'outter loop
··· repeat x from x1 to x2·······
······ 'some·'sysouts' for debugging
······ setXY(0,10)······
······ str(string("x="),0,black)
······ dec(x,black)·
······ 'inner loop
······ repeat y from a to fmath.fround((fmath.ceil(fmath.fadd(fmath.ffloat(a),b))))·
········ if(y =< y2)
·········· 'some·'sysouts' for debugging
·········· setXY(0,20)··
·········· str(string("y="),0,black)
·········· dec(y, black)··············
·········· setXY(0,30)
·········· str(string("a="),0,black)
·········· dec(a, black)················
·········· setXY(0,40)
·········· str(string("c="),0,black)·····················································
·········· dec(fmath.fround((fmath.ceil(fmath.fadd(fmath.ffloat(a),b)))), black)
············'·plot the dot
·········· plot(x,y,color)
······ a:=fmath.fadd(fmath.ffloat(a),b)
······ setXY(0,30)
······ dec(a,black)·
Thx!
Ahh! Tom Cruise! Use your witchcraft on me to get the fire off of me! ~Ricky Bobby
······· float a, b;
······· a = y1;
··········· a += b;
··· setxy(30,0)·
··· 'outter loop
······ 'inner loop
······ setXY(0,30)
Thx!
Paul Baker
I have re-arranged the y output a tad to be a little more usefull. Here's what I have now.
·b := fmath.fdiv(fmath.ffloat((y2 - y1) + 1), fmath.ffloat((x2-x1) + 1) )···································································
··· setxy(30,0)·
······ repeat y from a to fmath.fround((fmath.ceil(fmath.fadd(fmath.ffloat(a),b)))) step 1·······
······· setXY(0,20)·····
······· str(fstring.floattostring(y),0, black)
······· if(y =< y2)······················
·········· dec(fmath.fround((fmath.ceil(fmath.fadd(fmath.ffloat(a),b)))), black)··························································
······ a:=fmath.fadd(fmath.ffloat(a),b)··
······ setXY(0,50)
······ str(fstring.floattostring(a),0,black)········
·str(string("Fin"),0,black)···
Here's how the iterations go:
b = .2440945
hits the x loop: x=5
·drops to y loop : y increments from· 7.00649 e-44·to· 7.14662 e-44··(ok,·maybe·at first a·FloatToString error?)
·drops out of y loop:
·a increments·from 50·to·= 50.24412e-44
hits x loop again: x increments from 5 to 6
·drops to y loop again·: y·now starts to·increment (really slowly)·backwards! from 50.2441e-44· e.g. 50.2441e-44·, 50.2440e-44,· 50.2330e-44· etc!!
Zoinks!! what going on?
What spin is doing is it is taking the integer value that represents the floating point number and interpreting it as·that·integer:
Paul Baker
Post Edited (Paul Baker (Parallax)) : 4/16/2007 9:26:17 PM GMT
Good info.
What are my options (if any) for implementing the drawline method?
Joe
C does some automatic casting for you, you must do conversions back and forth between float and integer explicitly in Spin.
Paul Baker
That did the trick. I was on the right track, just strayed a little.
Thx for looking at it.
Joe
Paul Baker
