stamp controlled pcb drill — Parallax Forums
electromanjelectromanj Posts: 270
edited 2007-04-15 18:07 in BASIC Stamp
Hello, I would like to contruct a stamp controlled pcb drill machine. Any suggestions for getting started? I see that parallax offers stepper motors. Has anyone built one?
Thanks!
    edited 2007-04-15 03:31
    One-off or production? the stamp should be able to control the steppers and depending on your design should be able to repeat a position well but there is a lot of mechanical work needed. Tell us what you have planned.
    - Stephen
  • electromanjelectromanj Posts: 270
    edited 2007-04-15 03:43
    The mechanical part I can handle. I guess my first questions are:
    1. I am only familiar with the bs2. Will this be adequete?
    2. I am also curious about a source for couplers for the stepper motors. I plan to couple the motors to allthread for the x y movements, unless someone has a better suggestion.
  • RDL2004RDL2004 Posts: 2,554
    edited 2007-04-15 10:28
    There is a big long thread about a milling machine that may have some useful info for you.
    http://forums.parallax.com/showthread.php?p=539099
    - Rick
  • NewzedNewzed Posts: 2,503
    edited 2007-04-15 12:44
    Electro, I would strongly suggest you change to a Propeller.· My SuperMill was originally controlled by a BS2E and it worked pretty good, but it had its limitations.· Suppose it takes 5015 pulses to move the X axis 100 mils.
    If you want to travel 1 inch, that is 50150 pulses, which is approaching the limit of Stamp's capability.· If you want to travel 1.5 inches, it takes one command to travel 1000 mils and a second command to travel the remaining 500·mils.· With the Propeller and its 32 bit number, I can travel 6000 mils, which is the X limit of my mill.·
    Now suppose I want to travel 749 mils.·· With the Stamp I would write:
    pulses = 5015*/$077D = 35,731 pulses
    With the Propeller I write:
    pulses = (749 * 5015)/100 = 37,562
    That is a difference of· 169 pulses, which is about 3 mils.· I could go on but I think you get the idea.· Run some math where you are limited to 65535 for the Stamp, then run the same math where you are limited to 4,294,000,000 with the Propeller.
    If you have any question about my SuperMill, I will be happy to answer them.
    Sid
    Yesterday is history, tomorrow is a mystery, and today is a gift.
    That is why they call it the present.
    Don't have VGA?
    Newzed@aol.com
    thanks for the tips and links. alot of good info there.
