Propeller resetting in race environment
Hello all,
A question.
I have a propeller on a SMT pcb which is being used for data-capture and display within a race environment.· The circuit/code works fine when in the house, or connected to the car.· When the car is started the propeller starts to reset continuely.
The prop is in its own grounded box.· It is running of its own battery.
The problem goes away when you disconnect the RES, P30,P31 hookup to an external connector.
I've tried a 1k and 5k resistor pull-up/down on the RES line (cannot remember which way off hand) to see if its a "floating" issue.
Any other ideas?
Cheers,
James
A question.
Any other ideas?
Cheers,
James
If the battery is not inside the box as well, you'll need to filter those leads with chokes, small (0.1uF) and large (100uF) capacitors, ferrite beads, etc.
Shielded cables are not a bad idea.
thanks for the reply!
We have shielded cables - found that one last year!! I'll try the pull ups/downs and a choke or two for the next race.
Thanks!
james
any suggestions as to the values to use for the ferrite beads?
Looking at RS components (UK) they seem to be a frequency (25mhz) and a ohm type value (68 ohm) and a material type. Do you know of any simple guides to useage of
Would you put a bead on each wire, or one per group. I.e. one for rpm hookup, one for programming header (P31,P30,GND,RES), etc, etc.
James
I suppose that you have optoisolated all the lines that goes from the board to the sensors ?
If not, that's could be the problem.
If you've the board with his own box...you mean grounded it (where ?), or·a Faraday box ?
Make a Faraday box, and NOT connect it to the vehicle ground, also don't ground it to the peopeller ground, then the sensors wires must be shielded, and the outs from the box with ferrite breads.
I think that will solution the problem.
Good luck !
Regards.
Alberto.
http://www.parallax.com/dl/docs/prod/prop/SerialtoPropeller.pdf.
It's so sensitive that simply getting out of my chair near the circuit board makes it reset because of the discharge to my chair seat.· Removing the serial cable makes the problem go away, so I'm certain it's the way Reset is handled.· I haven't dug into it because in the real application the serial cable won't be used, but I have noticed that grounding the serial cable shield helps.
In those cases I use optoisolated RS232 lines, and no more problems then.
Regards.
Alberto.
the box is essentially a grounded faraday type cage. The box has to be grounded to the chassy as it has a common ground with some video camera's, which runs off the car battery.
The rs232 shields are already grounded. The sensors are shielded and contained within shields as best as possible.
Im looking into the ferrite beads - if not i'll have to loose the ability to re-program the box while "in" the car body by disconnecting the RES
Bizzarly the sensors work fine without any existing EMI shielding - bar the shielded cables mentioned above. Its just the reset of the processor.
Cheers,
James
You're supposing that the propellers resets due the RES pin...perhaps that is not true, and you've a lot of moise causing a reset NOT in the RES pin.
I think the best you've there is a dedicated power supply for the pchip, but if you don't optoisolated all, then ie: the camera wire gnd will be a big antenna for that, and also the sensors wires, altough you use a shield, and is poor !!
Power the camera with his own battery or the car battery, optoisolated the video input in the board, optoisolate all sensors and the serial comnunication, and forget all problems.
Don't ground the Faraday box !! isolated it from the car gnd !! only put a 0.001 uF with a 2.2 Mohm in parallel with it, and connect it to the 'box' and to the propeller gnd in the another side.
Regards.
Alberto.
Yeah, but it all works fine when you take off JUST the programming header (P30,P31,RES,GND). That is with the camera's, rpm, pedals etc, the box grounded etc. I suspect (though haven't tried) that if I cut the RES wire to the external connector it would still work fine. Only issue is then i loose the ability to re-program without disassembling the car and box.
I dont have the money to remake the pcb and to edit the board to opto-isolate and don't want to end up with lots of seperate pcb's as then you'll get reliability issues.
I suspect the 4.7k pull up/downs and ferrite choke will solve it. The RES line is only held high/low by a very weak internal resistor to the chip - so adding a meter or so of wire acts as a fantasic antenna!
If not - i'll likely loose/seperate the RES pin and just re-connect when required.
Cheers
James
Paul Baker
As to the faraday shield etc - It seems you've done some testing, and the single problem is the reset line - I'm prepared to believe your observation.
Here's my contribution. Add in·some bootloader / reprogramming software to your code. The EEPROM is not used while the Propeller is running, so it is safe to reprogram. The only real catch is that you have to write your own programming tool. Oh well. Al least you don't have to do any soldering. You can cut the reset line·once you've got your initial version of software loaded.
Thanks for the responses all. I've ordered some (lots of guess work) ferrite beads for this weekends race. We'll also try to make a metal cap on the db9 connector and do some testing.
I'll post an update after the weekend.
Cheers
James
I'd look at the grounds...
go opto on everything.
Rich
Update:
Well ran at the weekend at Cadwell (in North-ish UK) - nice little circuit at the bottom of a valley! Bugger to cycle round but thats another story!
Tried running the car engine in the garage with a makeshift cover for the programming DB9 (serial) connector which seemed to solve the problem. However on the first test session, you could see the prop rebooting (it has external LED sequences) as the car started / revved.
For the second session I took the decision to cut the RES connector off from the programming DB9 connector - this solved the reboots but enough noise is present (comming to this bit in a tick) to cause the prop to log data with some gaps - assuming enough "serial" data seen to slow it all down...?
Problem again solved with disconnecting the header completely - so a usefull exercise.
With regard to the noise - we have a lipo battery exernally now (for ease of change) - and I can see on the data 1v transients as Mike mentioned above. Some shielding required - but usefull to be able to "see" noise.
Plans:
1) Use a VGA extension cable (its double shielded and has built in ferrite) to run the pins to the control box.
2) Fully resess and cover the external connectors so when not in use!
Will keep updates comming.
James
What type of filtering are you using on your i/o's ? I ask this because I have used 'DSS31055y5S223Z50' murata items
(Radionics Part No.: 202-3471) in noisy environments with serial connections - and they have negated any nuisance noise..
I place these in line with the supply and any I/O lines ... might be worth a look...I have attached a pdf . There are various versions available..
Quattro
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 4/26/2007 2:45:54 PM GMT
