Bs2 i/o
The BS2's I/O pins accept High and Low input right? So why is it that you cant just wire a switched 5v to an input and read the switch activity? The whisker schematci from the boe-bot book uses 2 resistors and send a High (5V) signal constintly and the whisker actually shorts this curcuit to bring it Low.... Why couldn't it be Low all the time and go High when switched?
Here's a link for a different idea using capacitance from an insulated touch plate rather than induced voltages: www.bytecraft.com/Touch_Sensitive_Switch.
Post Edited (Mike Green) : 4/14/2007 5:46:58 PM GMT
