Barrel plug size?
What is the size (in mm) of the barrel plug (power plug) on the proto board.
I need to order some power supplies and could not find this out by reading any of the DOC.s
LewisD
PS. I know the proto board says 6-9VDC .....
Parallax
your 7.5 VDC 1A is backorderd
the 9 VDC 300ma is too small for me.
can I Use this 12 VDC 1A?
www.parallax.com/detail.asp?product_id=750-00007
Post Edited (LewisD) : 4/14/2007 7:08:02 AM GMT
LewisD
Parallax
Leon
The plug's OD is 5.5mm, bore is 2mm
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
The problem with the 12V supply is that the on-board 5V regulator has to dissipate all the extra power as heat. At 12V and 1A, that's 6+ watts. The regulator will probably shut itself down to prevent overheating. With a 7.5V or 6V regulator, that's only 1/2 to 2 watts.
Brian Meade
"They who dream by day are cognizant of many things which escape those who dream only by night" - Edgar Poe
