Serial Port Pin Tester
Here's my first propeller application! Somebody else may find it useful aswell.
I've designed and manufactured a prototype board which doesn't have the vga, video or keyboard stuff. So I wanted a little program to quickly enable testing each pin for continuity and shorts.
The attached example allows a terminal program to connect to the Propeller, and set each pin individually to either a high state, low state or a toggling. All pins not under test are set to inputs.
The toggling state toggles the pin high and low at a rate of 2Hz. This allows the audible logic level feature of my multimeter to be used to do the testing.
Feel free to use / modify / ignore as desired.
Can you post a picture of your board design?
regards
Dave M
Leon
The amount of board/componentry required to test the functionality of the supplied code is minimal. Basically, if you can connect to and program the propeller, then you have already got enough components on your board.
Edit:· The previous sentence is not quite accurate. You do need to have a crystal or oscillator - which is not required for programming.
Post Edited (mirror) : 4/16/2007 1:45:27 AM GMT
