Help with serial test program
MacGeek117
I've posted the program I'm having a problem with.
Every time I compile it, the Tool says "Blocknest stack overflow." I don't know what that means. Could I have some help?
RoboGeek
"I reject your reality and subsitute my own!"
Adam Savage, Mythbusters
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.startrek.com
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
PRI checkPassword(value) term.str(string("Enter passcode: ")) repeat while byte[noparse][[/noparse]value] if term.getc == byte[noparse][[/noparse]value++] term.out("*") else return false pause(1000) term.str(string("Passcode correct.")) return trueand you'd call this with 'if checkPassword(string("bugg"))'
Robogeek
www.parallax.com
www.expresspcb.com
www.startrek.com
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
Paul Baker
Typically, a program will save input characters in a buffer up to some delimiter, often the Return key, then the program can analyze the contents.
PRI readLine(bufPtr, bufSize) | c ' bufPtr is the address of a buffer (byte array) ' bufSize is the length of the buffer minus one repeat c := term.getc if c == 13 or bufSize == 0 byte[noparse][[/noparse]bufPtr++] := 0 return byte[noparse][[/noparse]bufPtr++] := c term.out(c) bufSize--RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
In your DAT section, just be sure to follow the string itself with a zero byte and be sure to use an input routine that does the same.
have the answer like answer 3, it displays this: Program space not available at this time.
To view program space, open current program and press F8.10
I don't know what is going on.
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
answer1 byte "I am fine.",0
answer2 byte "Version 0.9",0
answer3 byte 0
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
That tells me nothing about what sequence of inputs you presented to the program and what output it provided.
I can't tell what parts of the program executed and in what order without that so it's hard to tell what failed.
Hope this clarifies things.
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
Post Edited (RoboGeek) : 4/16/2007 6:14:23 PM GMT
If you can't do that, add a choice to the case statement "10:" and either follow that with "term.out(10)" or nothing depending on which you want.
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
