Conditional compiles or dead code removal?
Hi!
Pushing my current project from one corner into the other (within my head), I would like to have conditional compiles.
You know the C-style with #ifdef etc.
SPIN doesn't have that, so one workaround would be to relay on dead-code removal. Does SPIN do that? Albeit dead-code-removal wouldn't be the final solution, because it can't handle things like
or:
Is there some hope for a set of #ifdef-alikes?
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
OBJ #ifdef VGA Video : "VGA.spin" #else Video : "TV.spin" #endif
or:
CON #ifdef VGA xPos1 = 333 #else xPos1 = 444 #endif
Nick
YADRO
(EXAMPLE: I have a set of command codes that are sent from one Prop to another. The command codes come from different hardware interfaces and cross on wire and wireless links. It would be great to define and maintain those in one file and include them where-ever they are needed. Changes would then flow through with a re-compile.)
Just a though.
Are there any plans for enhancements to the Prop IDE?
Most of these requests would fall under the canopy of the compiler which was written by Chip. And he is quite busy designing the new chip.
Paul Baker
As you can well imagine, this issue will resurface over and over again until:
1) Parallax officially documents the Spin "object code" so some 3rd party can produce a compiler/IDE with additional features ... or
2) The compiler is released as separate module much as the tokenizer was for PBasic so a 3rd party IDE can be built ... or
3) The compiler is extended to support some kind of "pre-processing", either a built-in macro/conditional/include processor or an external one
The proposed C compiler from ImageCraft will relieve some of the pressure for this, but won't solve it because of the lack of Spin support.
The issue is that there are some organizational needs in the large / complex systems for the Propeller that are increasingly being attempted by customers that the current Spin compiler/IDE can't provide. In particular, there is the inability to straightforwardly provide for different hardware configurations and there are fundamental limitations in the object structure supported by the Spin compiler that make what would be straightforward object abstraction very difficult at best. Some of this is fixable with what seem to be simple changes (like an INCLUDE statement and/or an external pre-processor). Some might require changes to the compiler (like allowing objects without VAR space ... just some combination of CON/PRI/PUB/DAT).
this VAR is shared by all copies of the object (and thus only a single such object is
automatically shared across); or, another way of looking at it, this VAR section is just a
VARish way of declaring DAT.
This would give us the singleton objects we need, with no changes to the semantics we
have come to expect (except you have to change VAR to VARSINGLETON or some
such) and we are done.
There are cases this won't solve (for instance, you want a FullDuplexSerial for debug
but you also want an array of 10 FullDuplexSerials for other things; here we want one
big singleton FullDuplexSerial for the debugging, that is a Singleton, and then 10
non-singleton FDS for other purposes. But this is easily handled by simply using a
separate SingletonFullDuplexSerial.)
Unfortunatly it always comes down to management of resources and Chip's time is one of the most precious resources·of the company.
Paul Baker
BTW: The Proton IDE allows people to write their own plugins, and that's proven really useful...
Bets thing Jeff could do is make the compiler stand-alone, so it can be called from other app's / IDEs - must be a better way to go long-term?
Cheers,
Simon
BTW: I type as I'm thinking, so please don't take any offense at my writing style
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
T.
