Basic Stamp 2
Hello,
· I am trying to get Basic Stamp to get /accept numbers and depending on the number output a message to Emic voice synthesizer. My project is dealing with heart rate monitor that receives a pulse . I convert the pulse depending on the speed of the pulse, in PIC microcontroller, for PIc does not read PBASIC language ·and emic works well with· Basic Stamp.Hence I used·two microcontrollers.·I converted the pulse to a number 60-110 . I want Basic to receive· that number as hex· or ASCII.or whatever you suggest .·As each range of number 60-70 outputs a text to emic.
Therefore, I need your help with the program ,maybe you have a sample program that could do that.
Please help
Thank You
Please help
Thank You
The PBasic manual has all the information and examples you will need in the section on the SERIN statement.
I don’t see any reason why you couldn’t use the BASIC Stamp for the whole project. The BASIC Stamp can measure the pulses depending on pulse width. Or, if you’re looking for BPM you can use the count command. In any event the Emic example code shows how to send information to the Emic properly formatted, so your only real task is getting the code to read the pulses and integrate that with the speech code. Having a single microcontroller (if possible) will greatly simplify things. Take care.
