HOW TO: ASCII to Text
I have an array in ascii:
array(4)
I know that if I want to print the 2nd item in decimal format I go:
DEBUG DEC array(1), CR
But what if I want to print it in text format?
array(4)
array VAR Byte(4) idx VAR Nib array(0) = "X" array(1) = "Y" array(2) = "Z" array(3) = "!" FOR idx = 0 TO 3 DEBUG array(idx) " is the ascii character number ", DEC array(idx), CR NEXT END▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
DEBUG STR array
a zero will terminate the string. Take a look at the debug and the serial commands in the Pbasic help for formatting options.
Jeff T.
