IrRemoteButtons.bs2 modifications
I started with IrRemoteButtons.bs2 I was trying to modify it so that when you press the ChUp/Dn or VolUP/Dn buttons you can make the two continuous rotation servos speed up and down respectively but remain running at that speed until the next time you press the remote again which may be a long time between changes. what happens is it goes into the loop for the remote and doesn't come back until it gets a code I need it to check if it has a code and then come back with out one. if I haven't pressed a button.
[noparse][[/noparse]Moderator Added Subject]
Post Edited By Moderator (Chris Savage (Parallax)) : 4/12/2007 10:09:05 PM GMT
can you help! please....
you pointed me to what I was looking for.
Thanks again...
