SERIN using Xbee and and App-Sip module
I am trying to get the BS2 to recieve Bytes using the code that came with the App boards. Attached is the code can someone point me to where my mistakes are, because I can not recieve any characters.
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
BS2 homewoarkboard with APPBEE board and Xbee pro
Xbee Pro connected to PC using XCTU software
I can send from the BS2 and Appbee board to the other xbee that is connected to my PC. But I cannot recieve from PC to BS2. And I setup up both Xbees to the AppBee Documentation.
Same thing on the PC side, using X-CTU, restore all defaults.
Then try sending characters.
On other thing you can do is on the SIP side, connect TX to RX directly, and type characters on the PC side. It should echo the data back, with both LEDs blinking.
One last check is to swap the XBee's and make sure the other has not been configured by restoring defaults.
-Martin
