zapped my protoboard
well... somehow i managed to kill the propeller chip on my protoboard. somewhere on my robot a +12V lead managed to uncover itself, and after one last solid crash into a wall it was gone...
any ideas on how to revive it, if that is possible? for the time being i have my old board (a wulfden PRC) revived after 45 min of reworking solder joints... but i'd like to use the protoboard.
well, any ideas would be great. thanks so much
~~Brian
~~Brian
oh well. not that bad, only ~$20.
~~Brian
I have a Dremel tool, and the cutting wheel has very little wobble when running.
The other method of removing a chip is using a hot air rework gun, but if you don't have the right tip, then you're probably going to burn the PCB.
~~Brian
You could also use the Demo Board and some kind of I/O extender. I like the PCA9554 which is an I2C 8-bit I/O extender. It has good drive capability and is easy enough to control (look at BoeBotBasic). You can put it in a socket ... It's much easier and cheaper to replace than a Propeller if you destroy it.
http://www.chipquik.com/
Leon
Graham
"A man's errors are his portals of discovery.” - James Joyce
Quattro
'Necessity is the mother of invention'
I can second the really good light thing. I have a magnifying desk lamp which·does the job - I'd be happy with even more light, but the magnification is a good compensation.
