Memory-overwrites
Hi!
I know that this is a *very* unprecise question and that your answers will be even more vague. But I'll give it a try:
Writing an application, I see from time to time that I'm getting memory overwrites. I'm using the TV-object and when I do get an overwrite, I get fancy patterns in one of the screen's corners. Well, moving things around, I sometimes happen to fix them. Ain't the right way, I know!
The worst case I have now is with including the OBJ "keyboard". Just by the sole OBJ-statement (without any initialisation) my app doesn't start.
Now where do I have to look at?
The stack? But I only have one cock running my app and another one running some ASM I wrote.
I tried to write padding arrays of longs to see who might be the cause, but didn't help.
TIA,
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
TIA,
Nick
YADRO
The causes of this kind of behavior are legion. The best way to find the problem is to carefully go through the code checking that your assumptions about addresses, subscripts, stack sizes, etc. are actually followed rather than just assumed. Strange or odd problems can be due to stack overflow, but usually are not.
<G> I didn't want to hear that answer.
What I'd like to know is, that are pitfalls specific to SPIN. I'm (or was) familiar with many languages (and their pitfalls). So I do already pay attention to indices.
If I still don't get an answer I like, I'll try to boil it down and post the code.
Nick
YADRO
Paul Baker
Post Edited (Paul Baker (Parallax)) : 4/11/2007 11:32:33 PM GMT
I bet it is my error, but really don't have even the slightest clue where it is.
This example is quite boiled down, so you don't have to wade through lots of code. I have put comments where the problems appear (two traps)
{ I do have two problems with this code: 1.) If I just include the OBJ "keyboard", I get no display at all 2.) If I uncomment the VAR "filler", I get some overwrites to the screen and no display of the text } CON _clkmode = xtal1 + pll16x _xinfreq = 5000000 x_tiles = 16 y_tiles = 12 paramcount = 14 bitmap_base = $2000 display_base = $5000 lines = 5 thickness = 2 OBJ Scrn : "tv" gr : "graphics" floats : "FloatMath" floatstring : "FloatString" ' **** as soon as the next line is un-commented, the screen stays black ' kb : "keyboard" VAR long tv_status '0/1/2 = off/visible/invisible read-only long tv_enable '0/? = off/on write-only long tv_pins '%ppmmm = pins write-only long tv_mode '%ccinp = chroma,interlace,ntsc/pal,swap write-only long tv_screen 'pointer to screen (words) write-only long tv_colors 'pointer to colors (longs) write-only long tv_hc 'horizontal cells write-only long tv_vc 'vertical cells write-only long tv_hx 'horizontal cell expansion write-only long tv_vx 'vertical cell expansion write-only long tv_ho 'horizontal offset write-only long tv_vo 'vertical offset write-only long tv_broadcast 'broadcast frequency (Hz) write-only long tv_auralcog 'aural fm cog write-only ' **** uncommenting the next line makes some fancy pattern on the screen ' long filler[noparse][[/noparse]400] word screen[noparse][[/noparse]x_tiles * y_tiles] long colors[noparse][[/noparse]64] long flt PUB Main | Temp, i, dx, dy longmove(@tv_status, @tvparams, paramcount) tv_screen := @screen tv_colors := @colors 'init colors 'code was just copied from Graphics_Demo repeat i from 0 to 63 colors[noparse][[/noparse] i ] := $00001010 * (i+4) & $F + $2B060C02 'init tile screen 'code was just copied from Graphics_Demo ' **** Seems I can make some fancy color-fading with that. Don't need that, but doesn't matter repeat dx from 0 to tv_hc - 1 repeat dy from 0 to tv_vc - 1 screen[noparse][[/noparse]dy * tv_hc + dx]:= display_base >> 6 + dy + dx * tv_vc + ((dy & $3F) << 10) Scrn.start(@tv_status) 'start and setup graphics gr.start gr.setup(16, 12, 128, 96, bitmap_base) gr.textmode(4, 4, 6, %1010) FloatString.SetPrecision(5) repeat gr.clear gr.colorwidth(2, 3) gr.text(-80, 110, string("X:")) Temp:= 123 flt:= Floats.ffloat(Temp) flt:= Floats.fmul(flt, 0.00124) gr.finish gr.colorwidth(2, 3) gr.text(120, 108, FloatString.FloatToString(flt)) gr.copy(display_base) DAT tvparams long 0 'status long 1 'enable long %001_0101 'pins long %0000 'mode long 0 'screen long 0 'colors long x_tiles 'hc long y_tiles 'vc long 10 'hx long 1 'vx long 0 'ho long 0 'vo long 0 'broadcast long 0 'auralcogHope that someone of the (more than me) enlightened ones can help me.
TIA!
Nick
YADRO
Post Edited (Nick Mueller) : 4/13/2007 1:50:40 PM GMT
I have found one error on init colors. You have lost the index on left side of this expression.
repeat i from 0 to 63 colors[i] := $00001010 * (i+4) & $F + $2B060C02 [/i]That was discarded by the HTML-formatter (or whoever). The "[noparse][[/noparse] i ]" was interpreted as format-in-italic. Putting blanks around the i fixed that.
It is in the code.
I have fixed the posting of the code to display the brackets.
Nick
YADRO
Post Edited (Nick Mueller) : 4/13/2007 1:58:07 PM GMT
Paul Baker
Thanks, I'm aware of that and did check (albeit, I didn't post it). I do have more than 6000 stack/free.
That should be enough?
Even if I include a "_STACK = 200"*) and compile, it hangs when just including/importing the keyboard.spin-OBJ.
Could someone actually compile my code and say what I did wrong? I know that I sound dumb, but I also know, that I'm programming since decades.
That's something really puzzling me. Reading in the printed manual at page 107 it says that it will explain more, but I can't find more about it. I'm aware that there is some Stack-checker available (filling with A5-pattern). OTOH, I can't see why 6000 longs free shouldn't be enough.
Nick
YADRO
It looks like you're not actually using the graphics except to display text. There's a text-only display driver for TV output that takes very little memory. Have a look at "tv_text.spin" and "tv_text_demo.spin". There's also a more capable windowed text display routine by Phil Pilgrim (see: http://forums.parallax.com/showthread.php?p=590631).
Ah! graphics just takes the memory without some kind of defining/claiming it at compile-time. I have to do that by hand. Right?
Well, I need the characters in different sizes. And maybe some lines. I'll try the single-buffered.
Nick (more RAM!)
YADRO
Now I found my error.
Taking an N-th look at Graphics_Demo, I see the _stack statement claiming the memory for the bitmap and the buffer. And -tata!- it no longer compiles.
Thanks for your helping hands!
Nick
YADRO
Paul Baker
