Simple Propeller DIY prototyping board
I've just designed a simple prototyping PCB for the DIL Propeller chip. A photo of my prototype, the schematic, PCB layout and artwork files are here:
http://www.leonheller.com/propeller
The PCB is single sided, and may easily be made at home. I haven't bothered to drill all the holes, I'll just drill them as required. I've added a couple of·LEDs and the LP filters for audio output to the prototyping area.
Leon
Leon
Leon
I noticed when looking at the catalog they didn't offer such a thing? I like the idea of being able to replace the chip.
And an artwork too! Any chance of adding USB interface?
Nice Work,
-J
Leon
I have not moved up to a propeller and have only been investigating it. To be honest despite my relatively decent experience with basic stamps, I really would like to have multi-tasking and interrupt capabilities and move up to Propeller. Please correct me if I'm off base here.
Perhaps I'm still stuck in Stamp-Land as I was confused why the chips are so inexpensive, but the starter kits have surface mounted prop? With my record of frying stamps (When I was first learning the ropes) I'm concerned about having the same learning curve problems and I was thinking what you are doing was perhaps an alternative to having to return the whole board for an RMA if I fry it. I don't think I can replace a QFP chip. Looks like I would screw it up for sure.
I apologize for not looking and understanding it better first. But still I love your initiative! So, the propstick plugs into where?
Thanks!
-J
P.S. I was thinking of starting a post about the best way to go about learning the prop stuff. Propeller Starter Kit or perhaps Propeller Education Kit.
If you are looking to really understand the hardware aspects of things, I'd suggest the Education Kit or a combination of the Breadboard Set, PE Kit Project Parts, and PropSTICK USB which amount to the same thing with the convenience of the PropSTICK if you want to build a more permanent project later.
If you're a bit concerned about frying a Protoboard Propeller, get a bunch of 1K resistors and put them in series with I/O pins 0-15. Install the Accessory Kit so you can have a keyboard, mouse, and VGA display ... these, the EEPROM, and the programming port use most of I/O pins 16-31 anyway. Attach some 0.1" header sockets to the other end of the 1K resistors and you're set to do pretty much anything (except high speed ADC) on an adjacent breadboard.
Paul Baker
It isn't difficult to remove QFP chips if you use this stuff:
http://www.chipquik.com
You do need a bit of skill to solder the replacement chip, though. Drag soldering is the best way, with lots of gel flux.
The Demo Board is the easiest way to get started with the Propeller, but it's a bit expensive. It's good value, though, as it has virtually everything you need to get some interesting applications running as soon as you get it.
Leon
And Leon that is one interesting tool!
I think I will open the new post about prop details, as I appear to be digressing on Leon's completed project post.
I appreciate everyones help...I hope to see you on the other side.
Thanks Leon for the advice and congrats on your most excellent project!
-J
http://www.leonheller.com/Propeller/Prop%20and%20LCD.jpg
The Propeller is running the Parallax TV_Text_Demo.spin program.
The display is a 2.52" Pustom colour LCD monitor and cost me about £48.
Leon
Post Edited (Leon) : 4/16/2007 12:12:58 PM GMT
