Need help getting Tracking freq generator to work!!
I have used the Propeller chip on numerous projects and I am very impressed with its capabilities. I find more and more each day.My problem is: I need to generate 4 distinct frequencies. 3 are preset and that section works very well. The 4th section needs to track an incoming frequency and multiply it up by 100. It works when the software first starts then does not track or reset the 4th generator. i am at wits end...Any help would be appreciated.
Regards
OBJ
· Freq : "Synth_sweep_BP"
PUB CTR_main····················································· ''' Start of Main Routine
· DirA[noparse][[/noparse]5]:=%1··········· 'control signal
· Dira[noparse][[/noparse]7] :=%1·········· 'control signal
· DirA[noparse][[/noparse]3] := %0········· 'counter in
· DirA[noparse][[/noparse]6] := %1········· 'auto in
· DirA[noparse][[/noparse]10] := %0········ 'ms start sequence
· OUTA[noparse][[/noparse]7]:=%0
·· dirA[noparse][[/noparse]0..2]:=%1······· ' output ports 0,1,2
· dirA[noparse][[/noparse]9]:=%1
· OUTA[noparse][[/noparse]9]:=%1··········· 'set port to output 1
· dirA[noparse][[/noparse]11]:=%1
· OUTA[noparse][[/noparse]11]:=%0·········· 'set port to ground
· cognew(ref_in,@stack4)······················ ' output 240 hz clk· always active··························· works
· cognew(FirstCtr,@stack3)···················· ' output 20khz and 24khz clocks always active·········· Works
Repeat
· get_freq······································ 'read input freq and update 4th counter
repeat
''####################· end of Main Routine
PUB FirstCtr
· Freq.Synth("A",Pin,FrequencyB)······ ' 20khz·
· Freq.Synth("B",PinA,FrequencyC)····· ' 24khz·
repeat
pub get_freq···
··· Frequency1 :=0
··· CTRA := 0 'Clear CTRA settings
··· CTRA := (%01010 << 26 ) | (%001 << 23) | (0 << 9) | (3) 'Trigger to count ' rising edge on A4
··· FRQA := 1000 'Count 1000 each trigger
··· PHSA := 0 'Clear accumulated value
··· WaitCNT( 80_000_000 + CNT ) 'Wait for 1 second
··· Frequency1 := PHSA / 1000
··············· if Frequency1 > 20 ' and INa[noparse][[/noparse]6]· enable at a later time bit 6
····················· freq2:=frequency1*100······ ' need 100 times roll-off freq
····················· Freq.synth_sweep (Freq2)·· 'Should set new frequency in counter·4
··· WaitCNT( 80_000_000/100 + CNT )
repeat
pub Ref_gen2···· ' not used in this program
·}············································· ' keep cog alive
pub ctr_sweep
· Freq.synth_sweep(freq2)
repeat
pub ref_in
Freq.ref_gen
repeat···························
'··································································· The following works but only on first pass through
pub synth_sweep (Freq2) | s, d, ctr, frq
·· if Freq2 < 500_000···················
··· ctr := constant(%00100 << 26)·····
··· s := 1····························
·· else································
··· ctr := constant(%00010 << 26)····· '..set PLL mode
··· d := >|((Freq2 - 1) / 1_000_000)··· 'determine PLLDIV
··· s := 4 - d························ 'determine shift
··· ctr |= d << 23···················· 'set PLLDIV
·· frq := fraction(Freq2, CLKFREQ, s)··· 'Compute FRQA value
·· ctr |= 2'Pin·························· 'set PINA to complete CTRA/CTRB value
···· CTRA := ctr······················· 'set CTRA
···· FRQA := frq······················· 'set FRQA··················
···· DIRA[noparse][[/noparse]2]~~······················· 'make pin output
repeat·································
Post Edited (Armondo522) : 4/9/2007 7:38:26 PM GMT
Regards
OBJ
Repeat
repeat
PUB FirstCtr
repeat
pub get_freq···
··· Frequency1 :=0
repeat
pub ctr_sweep
repeat
pub ref_in
Freq.ref_gen
http://www.parallax.com/dl/appnt/prop/AN001-PropellerCounters-v1.0.zip
Do you care about matching the phase of the input frequencies? Are you aware of the fact that since you are only using a 1 bit DAC (MSB of phase register), there will be a lot of jitter if you work at high frequencies?
Also, I am having trouble understanding the "repeat"s in your code. There's a feature in the IDE view options that helps the visualization of the indentations by adding light gray lines to group blocks of code.
I do not care about phase jitter or phaseing. The highest freq i will put out is 3 MHZ. It appears to read the frequency correct, but only on the first pass through the routine. After that it appears to ignore the whole get_freq routine. I put the repeats in to keep the cogs alive..is that a wrong assumption. If i take the repeat out, the frequency changes, but at a 10 ms rate which is unacceptable. I will keep on pluggin
thanks again.
I'd recommend that you use the GEAR Windows emulator to load up your program and check how the cogs are running. Scroll to the end of
http://forums.parallax.com/forums/default.aspx?f=25&m=164602
and obtain your copy.
Also, you need to download the Microsoft .net extensions mentioned in the thread.
Thanks for the help. The problem was I was reading and writing the frequency info to the same counter..One should have been A the other B..It works great now...
