Connecting Stamp I/O pins
All--
How do·I connect a dedicated Stamp output pin to a dedicated Stamp input pin on another Stamp?·I want to·experiment with some VERY rudimentary communication among Stamps. I want a Stamp to do some work, then tell another Stamp the results. The results may be as simple as setting a pin to indicate the work has been performed, or setting a pin to indicate the work has been done followed by a byte representing the work done. (I only need to communicate a few inches; say from one BOE to another as closely as I can place them.)
It sounds simple. Is it?
Thanks.
--Bill
ps I am fairly certain that I have seen this discussed. But, my SEARCH revealed little.
You are what you write.
Thanks.
--Bill
Does the current limiting resistor simply connect the two pins? (Forgive my ignorance.)
Thanks!
--Bill
Thank you so much!
--Bill
http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv16.pdf·is a primer on serial communications and seems like it may be of help.
Thank you! I saved it on my machine!
--Bill
