iRobot Packbot DIY
I want to build a Packbot-like tracked robot that can climb rough terain and stairs. Be controlled remotely or autonomous. Mini-Videocam and PS2-like controls
Building bipeds (or thiking about them) is fun, don't spoil it.
I am in the process of attempting to build a robot that will have many of the same capabilities that you have requested.
The path is not easy and I have had to do a lot of research on the web that has yielded a fair amount of useful information about what I want to accomplish.
The kind of robot that you want to build will have to be fairly robust and it seems that you want to make a scaled down copy of the iRobot Packbot. Why not start with iRobot support and see what they have to say. You might also get on the Create Forum and indicate what you want to accomplish and see if you can get any responses.
Just a thought.
TCIII
If you are going to send someone to save the world, you·better make sure that they like it the way it is!
