parallax RF transmitter problems
In a previous post I asked how to use the PDN pin of the Parallax transmitter. I used a blocking diode to limit the voltage and everything worked fine...except I wasn't able to pull PDN low and put the transmitter in low power mode. However, with all this talk at UC about powering it down with this pin, why can't I simply connect an I/O pin to the Vdd input on the parallax 27980 transmitter module and control it that way. In other words I would be cutting power to it at will or powering it up as I please. Would this damage the transmitter, the development board or the BS2? I can't imagine why it would as it is not going above 5 Vdc. Any advice would be great. Thank you.
Louis Blessing
Louis Blessing
- Stephen
Louis
