my photoresitor burnt out so i bought a photo transitor, now trying to figure o
I put the phototransitor in with a 10K resistor it senses a ir remote control but it is not sensing my pulseout from the prop how would i do that? or maybe i could just use my last photoresceiver in the center but it doesn't work very well with only one photo reciever
I point the· ir transmitter directly at it and it doesn't work I am using this command
Pub main
· FDS.start( 31, 30, 0, 19200)
· pulseOut(6, 3000, 2000, -1, 0)
· repeat
··· 'FDS.str(String("test"))
··· if pulseOut( 1, 38500, 385, 0, 1)
····· FDS.str(String("Right"))
··· if pulseOut( 2, 38500, 385, 0, 1)
····· FDS.str(String("Left"))
Pub pulseOut(pin, freq, dur, checkPin, checkVal)
·· ctra := ctrb := 0························· ' Stop counters if running
·· frqa := calcFrq(freq)····················· ' Get FRQA for frequency
·· frqb := 1································· ' Neg edge -> PHSB + 1
·· phsb := phsa := 0························· ' Clear phases
·· outa[noparse][[/noparse]pin]~
·· dira[noparse][[/noparse]pin]~~······························· ' Pin to output low
·· ctra := %00100 << 26 | pin················ ' CTRA -> NCO
·· ctrb := %01110 << 26 | pin················ ' CTRB -> Negative edge
·· if dur···································· ' Go forever if dur = zero
····· repeat until phsb => dur··············· ' Cycle counting loop
········ if checkPin => 0
········· 'FDS.dec(ina[noparse][[/noparse]checkpin])
··········· if ina[noparse][[/noparse]checkPin] == checkVal····· ' Quit early if condition met
·············· result := true
·············· quit
····· waitpeq(0, |< pin, 0)·················· ' Make sure pin is zero
····· ctra := 0······························ ' Stop CTRA module
····· dira[noparse][[/noparse]pin]~····························· ' Make pin an input
····· ctrb := frqa := frqb := 0·············· ' Clear counter modules
PRI calcFrq(f)
· {Solve FRQA/B = frequency * (2^32) / clkfreq with binary long division.}
· f <<= 1
· repeat 32·································· ' Binary long-division
··· result <<= 1
··· if f => clkfreq
····· f -= clkfreq
····· result++·······
··· f <<= 1
thanks for your help
Pub main
· repeat
·············· quit
PRI calcFrq(f)
· f <<= 1
··· result <<= 1
··· if f => clkfreq
····· f -= clkfreq
··· f <<= 1
