PIEZO is not very loud using FREQOUT
Help with Freqout - I connected the piezo speaker·to pin 7 on the BS2 and it is not very loud at all.· Any clues?· I have the BS2 in a socket.· My BS1 USB chip is way louder using the SOUND command.· I would assume that the drive from the BS2 was equal or even better than the BS1?· Any one have the same experience?·· Is it related to the way that FREQOUT sends the signal to the Piezo?
Messing around with the WaM kit, I've found that a 1000Hz tone is fairly quiet, while a 3500Hz to 4500Hz tone is considerably louder.
My hearing is pretty bad but I expected it to be louder than that.
·· Speakers,·especially Piezo Speakers have what’s called a resonant frequency. The speaker performs best at and around this range of frequencies. I believe the Piezo we carry has a resonant frequency of ~3500 Hz, so frequencies in this area will be louder than all others. Especially difficult to produce would be frequencies outside the frequency range of the speaker. For example, you won’t be producing 20 Hz bass from the Piezo. I hope this helps. Take care.
Nellastav made no mention of the freq. used for each stamp. Perhaps they were NOT the same.
>command than with the Freqout on the BS2 ?
Because the 'sound' command produces a squarewave which has the fundamental plus higher harmonics (which the piezo can respond to (it's a tweeter only))
The 'freqout' command produces a sinewave pretty devoid of harmonics.
