Pulsout/Serout question
Hi there,
I am sending information via RF 433 units and wonder if anyone has more information about the Pulsout that goes before the Serout.
as in:
PULSOUT rfpin, 2200
SEROUT rfpin, 240, [noparse][[/noparse] "1", DrivePotVal.HIGHbyte, DrivePotVal.lowbyte, TiltPotVal.HIGHbyte, TiltPotVal.lowbyte, RelayOnCar ]
The text for the RF unit (from parallax) has a value of 1200 for the pulsout - but I switched to a bs2sx and the value doesn't work. How do I pick the "right" value? The text is lacking in this area. Some values seem to make my transmission stutter a bit ( I am driving servos ). Should I just experiment or is there a way to figure this.
Thanks!
Carlos
(here is the text from the parallax website)
Calibration
When initiating communication between the RF modules, a sync pulse should be sent to re-establish the
radio connection between the modules. Sending several characters can accomplish this, however
sending a pulse (which maintains a high state during the synchronization) is more efficient:
√ For BS1s the following code line sends an appropriate sync pulse:
PULSOUT 1, 300
√ For BS2s the following code line sends an appropriate sync pulse:
PULSOUT 8, 1200
as in:
PULSOUT rfpin, 2200
Thanks!
Carlos
Calibration
PULSOUT 1, 300
PULSOUT 8, 1200
The best trick here is to use conditional compilation to set constants for values you will use in these commands. That way when you compile for any kind of Stamp your code will work without changes.
Here's some sample code with conditional compilation and constants for pulsout that might show what I mean a little better:
' ========================================================================= ' ' File....... SW21-EX26-Servo_Control.BS2 ' Purpose.... Servo control and positioning with a potentiomenter ' Author..... (C) 2000 - 2005, Parallax, Inc. ' E-mail..... support@parallax.com ' Started.... ' Updated.... 01 SEP 2005 ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' ' This program shows how to control a standard servo with the BASIC Stamp. ' Servo position is controlled by reading position of a potentiometer that ' is part of opposing RCTIME networks. ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- PotCW PIN 0 ' clockwise pot input PotCCW PIN 1 ' counter-cw pot input Servo PIN 2 ' servo control pin ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- Scale CON $00C6 ' to scale RCTIME values Center CON 1500 ' servo center position #SELECT $STAMP #CASE BS2, BS2E, BS2PE PwAdj CON $0080 ' pulse width adjust (0.5) #CASE BS2SX, BS2P, BS2PX PwAdj CON $0140 ' pulse width adjust (1.25) #ENDSELECT #DEFINE _Testing = 0 ' 1 for POT testing ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- rcRt VAR Word ' rc reading - right rcLf VAR Word ' rc reading - left diff VAR Word ' difference sPos VAR Word ' servo position pWidth VAR Word ' pulse width for servo ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- Reset: LOW Servo ' initialize for PULSOUT ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: HIGH PotCW ' read clockwise position PAUSE 1 RCTIME PotCW, 1, rcRt HIGH PotCCW ' read ccw position PAUSE 1 RCTIME PotCCW, 1, rcLf #IF _Testing #THEN ' display raw values DEBUG HOME, "CW (raw) ", TAB, DEC rcRt, CLREOL, CR, "CCW (raw)", TAB, DEC rcLf, CLREOL, CR #ENDIF rcRt = (rcRt */ Scale) MAX 500 ' scale RCTIME to 0-500 rcLf = (rcLf */ Scale) MAX 500 sPos = rcLf - rcRt ' position (-500 to 500) pWidth = (Center + sPos) ' finalize pulse width #IF _Testing #THEN ' display scales values DEBUG "CW ", TAB, TAB, DEC rcRt, CLREOL, CR, "CCW", TAB, TAB, DEC rcLf, CLREOL, CR, "Pos", TAB, TAB, SDEC sPos, CLREOL, CR, "Pulse", TAB, TAB, DEC pWidth, CLREOL PAUSE 100 #ELSE PULSOUT Servo, (pWidth */ PwAdj) ' move the servo PAUSE 20 ' servo refresh delay #ENDIF GOTO Main▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
I did think that I could just multiply my pulsout value by the unit value for the bs2sx, but it didn't quite seem to work right - I guess I'll just stick with that though...
I wonder if I should use a pull down resistor on the output (data) pin for the rf transmitter (which is active high) to "clean it up"? Or would that be a bad idea?
Carlos
