Saving a Variable in EEprom
I know....I have read this somewhere.
I've looked for the post....but just can't find it.
Could someone refresh my memory about this.
If I remember correctly, a variable can be stored back into the eeprom, and the propeller will know this variables value(upon boot)·until it is saved(changed) again.
Also since the propeller knows the variable location .....it is quite simple.
I think Chip said something about this.
I hate to ask something I know is here.....just it eludes me.
James L
James L
Thanks for the response....I knew it was pretty easy.....and is real cool that it will work that way.
I knew I had read that somewhere.
I'll copy and save this information for my use. I'm starting to do that with anything I think I might need. It is easier than trying to find it later.
James L
There are two different I2C objects in the Propeller Object Exchange that will do EEPROM access for you. Have a look.
