PLL Burnout
Like most propeller projects, I'm currently doing a project that that uses the _clkmode = xtal1 + pll16x command.· However, one day, I noticed that it started to only work with _clkmode = xtal1 or _clkmode = RCFAST.· The pll comands stopped working completely.· Any idea why·it stopped working?
Craig
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning.
Microsoft: "You've got questions. We've got dancing paper clips."
Craig
Do you have any pics of the prop circuit and associated hardware used ?
Did you read this thread ?
http://forums.parallax.com/showthread.php?p=639324
Sorry for all the questions but I'd love to know what is causing this - so as to definitely protect against it ...
·········· Quattro
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 4/4/2007 12:55:20 PM GMT
If this is a home-brew board just make sure your leads are as short as possible, like don't have the crystal sitting in a convenient socket a few inches from the prop.
*Peter*
I agree with you there on all points - but thats a few such PLL failures I have read about - on Proto Boards etc .. there's more to this I think..
Quattro
Depending upon the design of the PLL it could be rather sensitive to noise or harmonics. Crystal ain't crystals and depending upon the manufacturer, batch, handling, age, circuit, etc the performance and operation can vary wildly.
If anyone has an oscillator problem then the very first thing that should be checked is the crystal and the physical circuit. Preferably try another brand crystal in case there is a batch problem. A crystal that works perfectly well in one type of circuit may not in another type of circuit. There are $5+ crystals and seemingly identical 50c crystals, what's the catch? Most of the time the 50c one is fine, most of the time.
Craig, go through the checklist mentioned earlier and always cross-check if anything changes by reverting back and checking just in case it was a bad solder joint or something.
*Peter*
As per previous post ...... there is of course the obvious checks - crystal or oscillator and connections etc.... - however this has popped up as a 'silicon failure' on a number of occasions which could be a concern in terms of application 'best practices' when connecting devices etc .... with a number of damaged props the first point of failure has been PLL (and where the crystal oscillator still works) - as described in the link in my earlier post -... this can't be ignored - we'll have to wait for feedback from Craig to see...
in the post I supplied earlier ...
Quattro
Post Edited (QuattroRS4) : 4/4/2007 1:26:29 PM GMT
BTW, how many complicated and mysterious problems have we seen on this forum alone that have turned out to be simple simple problems that have been missed because the simplest checks were not carried out properly. Too many!!!!
*Peter*
*Peter*
Either way we need to see some more input than just my PLL quit working!
With regards to·misconfiguring the I.C supply - agreed that is a scenario that is beyond the remit of any IC manufacturer - that is not really my point of interest in this whole matter - interesting point about that scenario, though, is the point of failure - PLL.
·The aspect of this 'problem' that does interest me though is the 'current inrush' - e.g.·back emf generated by an inductive load and also the ground loop aspects·...
I agree wholeheatedly with what you are saying .. Based on the few posts regarding this issue - I ran some destructive tests - the results of which were sent to Chip - whereby inrush current as a result of switching inductive loads repeatedly emulated the same said issue - oscillator fine PLL not working .. I then fitted filters VRF303 series and ran the same tests - without issue.. That is not to say that these tests were definitive but rather the issue can be emulated to a certain degree . Also there will of course be some props more prone than others as is the nature of IC manufacture..
Yeah I have seen the DOH ..... scenario - a simple solution to a puzzling problem..
and Yeah - and I bet the Prop and Boards are fine but at least this will lead to warnings and procedures being put in place to avoid such issues . I have many props in industrial applications running 24/7 switching inductive loads etc - without issue - PCB's with Ground Planing,filters,suppression on contacts etc - but all derived from a 'prototyping'·process as with Craigs current issue ..
P.S - Before I forget - saw your prop board on another post - nice job !
Quattro
Post Edited (QuattroRS4) : 4/4/2007 2:02:05 PM GMT
Craig
Absolutely yes is the answer but ,as with all, low voltage microcontrollers circuit design is critical.As I have previously mentioned - I have quite a few Propellers and Stamps in 24/7 industrial applications all with inductive loads pnuematic solenoids, relays, and contactors for high current 380 - 415v 3phase motors -
I have used filters in line with all outputs I have coil suppression on relays and contactors
and contact suppression on contacts, P.C.B's are heavily ground planed - not just to eliminate spikes upsetting the controller but also for CE certification - I don't want to be 'generating' noise either.
see attached apps:
This is a sample of one of the Prop apps:
video.google.com/videoplay?docid=-4731155379062352204&q=Parallax+propeller
This is a stamp based app:
video.google.com/videoplay?docid=-7703119114106288120
One from the 'food industry' - during prototyping/trials .
http://video.google.com/videoplay?docid=4421309128503441226
Craig - do you have a schematic or pictures or both of the app ?
Quattro
Post Edited (QuattroRS4) : 4/5/2007 3:10:03 PM GMT
One thing that's very important is how your power is routed. If the Propeller and high-power devices must share a common ground, be sure to connect each via a single cable/trace to a common point right at the power supplies. Do not assume that ground connections can be made at random — even to a heavy ground plane. You don't want ground currents from other devices flowing through the Propeller's circuitry. Better still would be separate grounds and optical isolation.
Quattro,
Nice app, that ball counter! What kind of sensors did you use to detect them? Are the balls still channelized when they're counted?
Sensors are 'SICK' - polarized retro reflective. Interesting that you asked whether the balls are channelized - Yes they are - during prototyping and when the volume was high the balls would knock off each other - disrupting the count ..The sensors are slightly off centre to pick up the space between balls if they were on top of each other going through (i.e. if balls were touching each other going through and the sensor was centre then it would only 'see' 1 ball - hence off centre).The count is also very accurate - as was the requirement.The whole top section sensors included can be removed to set up for a different ball size. I have 8 of these counters at that site with - all different ball sizes - in case you were wondering what the balls are for - roll on deoderants mostly! The feed conveyor and dryer section are now controlled by the this unit - over temp means the ball will swell (they are hollow) and not fit through the grading grid..There is also a link to shop floor data collection system..
The stamp application shown - is controlling a· 'grinding' process - the machine has a 11Kw (approx 15hp)
380V ac main motor, a 3.75Kw(5hp) 380V ac·hydraulic pump system, pneumatics and 24V DC·control - and
there is a fair degree of filtering going on there for contactors etc .Used Siemens contactors and a Siemens SITOP PSU··- I have always found them reliable .There are 28 of these units - they look filthy but it is a wet grinding process that runs 24/7.
Quattro
Screen Images of Latest Version Propeller·Based Ball Counter .... Link to Rework Station etc...
Post Edited (QuattroRS4) : 8/2/2007 11:09:21 PM GMT
Craig
P.S. On the same project, the program stores a few values in the EEprom for use next time it turns on. However, occasionally it seems to loose the info. Any Idea why? I realize that loading another program would wipe these values, this is a different issue.
If so - I saw a routine by Mike Green which toggles pins before first read/write ...
ah - I eventually found it -
Quattro
Post Edited (QuattroRS4) : 4/6/2007 12:48:10 AM GMT
Thanks for the reply, but I'm afraid I don't understand. The prop reads the code from the eeprom at startup, about 1 second after it starts running the code, it reads 12 bytes from the eeprom. If you could, please just explain your reply a little more.
Craig
So this routine runs a clock pulse (SCL) x 9 and repeats·if SDA is not·high - and hey presto problem solved - I have used it and it does work...
Is it the first read/write after a reboot that is causing your problem ?
Quattro
Post Edited (QuattroRS4) : 4/11/2007 2:45:27 AM GMT
Thanks Again,
Craig
