Sony IR Decoder IC???
Mitch
Anyone...
Something caught my eye in Tom Petruzzellis' book "Stamp 2 Communications and Control Projects". On page 42 under SONY Infared Decoder Chip he mentions the 8-pin SONY IR Decoder.
Does anyone know where I can get one? I'm building a Halloween display that I want to control with a Sony compatible TV remote controller.
It looks like an interesting beast. It converts the 12 bit serial stream (coming fromthe controller) to a straight 8-bit ASCII code then sends it on to a STAMP2 controller. You connect it to a 40MHz IR Detector (Liteon, Radio Shack, etc.).
Mitch
Mitch
This might help..This is a good website.
I saw this chip last night. It appears that each button that is supported requires a separate pin on the stamp. The one referenced in the book is an 8-pin package and pin 7 is TX to send the 8-bit code to the STAMP pin.
I guess one other option would be (provided there is and IC to do this) to assemble D0-D14 into a data byte and and then send tthe byte to the STAMP pin...
The SONY chip discussed in the bookseemed too good to be true. I'm trying to find a way to get ahold of Tom to ask him for a source.
Mitch
home.earthlink.net/~henryarnold/
