Question — Parallax Forums
Question
AccountAccount Posts: 1
edited 2007-04-04 03:59 in BASIC Stamp
Can you have the gripper & The tank tread kit on your Boe-Bot at the same time?
    edited 2007-04-03 23:50
    Hello,
    The two kits are not compatible/friendly with each other due to the nature of the modifications in both cases. Take care.
  • DufferDuffer Posts: 374
    edited 2007-04-04 03:39
    Account,
    Since Chris has already said that the Parallax Gripper isn't compatible with the tank tread kit, you might want to take a look at an alternative "gripper" from LynxMotion:
    ·http://www.lynxmotion.com/Category.aspx?CategoryID=61··
    Look at the last three items on the web page.
    It's a simple 2-servo, lever actuated gripper. If it will fit between the tracks on the front of the Boe-Bot, it should work. Also, because the whole assembly mounts to the front of the bot (no push/pull rods), you can easily just move the whole assembly forward on an extension bracket to clear the tracks if you need to.
    Good luck,
    Steve
    Post Edited (Duffer) : 4/4/2007 3:46:36 AM GMT
  • ZootZoot Posts: 2,227
    The Lynxmotion gripper is pretty nice. Lightweight too. One thing to keep in mind -- the Lynxmotion gripper *rotates* and grips, but does not *lift*. The Parallax gripper only grips, but as part of the same mechanical motion on the same single servo (the final travel of the pullrod), the gripper lifts just a bit. Just something to consider.
