Shameless plug for Xenon products
It can't be any easier to do RF control then this little package. Right out of the box, the keyfob has 4 buttons A,B,C and D (The battery is already in it too!) the receiver has +5V and ground, a data valid pin and 4 other pins that simply go high when you press any of the 4 buttons. Best of all,my house is 50 feet long, at one end I have the receiver and from one floor below (finished basement with soundproofing in ceiling as well) at the opposite end the unit works perfect.
I connected 5 LEDS with 1K resistors on each of the output pins and the data valid pin to test the range. Stuck a bit of wire in the antenna hole without even soldering it in.
I bought some of each of the other units they sell as well to experiment with.
So make yourself a keyfob controlled light switch or whatever this little thing rocks.
Hint: go to the transmitter only and receiver only to buy the combo for about 1/2 what is listed in this link.
http://www.xenon-tech.com/index_eproduct_view.php?products_id=3
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Then 4khz square wave and again rock solid. (in same room)
I will have to put the transmitter on a portable board to test range for high freq signals but I am playing with so many projects now I don't have any empty breadboards, yikes...
Tested its range , I can go to any point in my house and receive the signal perfectly clear.
http://www.xenon-tech.com/index_eproduct_view.php?products_id=4
Would be interested to see how it works with 'noise' or other interference (other products on same freq).
Might be worth developing a little scheme to modulate your signal (or just pulse code it).
cheers
Steve
