Wireless output to stamp
I was wondering what would be a better choice for outputing a signal to the BS2, the EmbeddedBlue Transceiver AppMod or the Parallax 433 MHz RF Transceiver Package? I will have two output sources, but in different locations so two transmitters/receivers are needed and I do have limited space for the transmitter. The output signals will be transmitting data from two arrays of sensors to the BS2 from within a foot so transmission distance isn't much of a factor.
Steve
Steve
If you can't use the xBee, I'd suggest the EmbeddedBlue Transceivers since they do provide an error-free virtual serial channel. With the Parallax Transceivers, you have to add your own error control.
I use the xBee for communications between a BOE-BOT using the Propeller and a MacBook, but I have used the AppMod adapter with a Stamp. Works great.
Post Edited (Mike Green) : 4/3/2007 5:01:50 AM GMT
