Finding people
I'm working on a robot, I would like to have it seek out people in a room. my thoughts were to have the robot move to a spot, and sit for a minute or two... or as soon as it locates a person. while sitting it would monitor one or more motion detectors. if the motion detector goes off. then persumabley, there would be a person in that direction. I would then sweep with a Ping sensor determine the most open path in the direction where movement was detected. The robot doesn't need to touch the people it detects a foot or 2 would be fine. but I think the above method is a little coarse espically if people are close. does anyone know of a different sensor that I could use to detect people at close range, 1-3'? I thought I read somewhere a while back about using dielectric curetnt to detect people. I've searcher and I can't find any other topics that talk about this. Does anyone have experience in this area? any suggestions on how to locate people?
Any info would be appricated
Dave
Dave
Does anyone have experience with such techniques ?
Ed
The thermal sensor array from Devantech (while initially designed for fire-fighting contests and the like) will let you get a rough direction towards a "warm" body. Steve Norris built a Propeller-controlled crawler using this sensor: http://forums.parallax.com/showthread.php?p=615077
