Multiple Output voltages for different parts of a robot ?
Hi everybody,
In designing a robot using different parts like servos, DC motors etc, whats the most efficient way to provide regulated voltages to these devices?
My robot has parts that need the following voltages:
1. DC gearhead motors - 7.2V
2. Servos - 6.0V
3. Basic Stamp 2 - 5.0V
4. Servo Controller - 5.0V
5. DC motor controller - 5.0V
3. RF Transceiver - 3.3V
I figured using LM7805, LM2937-3.3 etc in tandem to get the different voltages from one source will generally not be the most efficient way to go. Moreover, the servos (6 giant servos, and 4 gearhead motors will need a lot of juice.
So whats the most efficient way to go?
Thanks everybody for your suggestions.
E=mc^2
2. Servos - 6.0V
E=mc^2
Mike Green provided invaluable pointers in wiring multiple regulators and loads to a single power supply in this thread: http://forums.parallax.com/showthread.php?p=610598. Following suggestions there I am running 5 loads from 4 different regulated/unregulated voltages without problems. Unshown in that thread is the feeding of the 9v regulated supply into the 5v regulated supply so as not to over-burden the 5v regulator.
Lastly, the addition a few heavy-duty diodes between the battery and the main logic supplies did two things -- helped drop the unregulated battery voltage a bit further to ease the load on the linear regulators and helped prevent a ground-loop lockup on my motor driver when I hit the motor supply kill switch. With switching regulators the burden on the reg. itself is obviously less of an issue. Had I known about some of the integrated switching supplies when I built the boards, I probably would have used them (but they are big).
