Simple issues with passing variables.
i'm having trouble getting another cog to update a variable in the main program. A array of byte sized variables is created in the top object, whose pointer is passed to the sensor object. i was thinking that this would continuously update the variable in the main object. but all that i am getting in the top object is zeroes.
here's my top object code:
and here's my sensor object code:
but when i do this in the sensor object and run it stand-alone it gives me legible (while inverted... :-\) data:
i'm not sure what i'm doing wrong, hope it's something small and someone'll point it out right away.
Thanks!
~~Brian
Post Edited (Litefire) : 4/1/2007 3:09:40 AM GMT
OBJ
motor : "SetMotor"
bs2 : "BS2_Functions" 'remove when we're done
sensor : "Sensors"
encoder : "Encoder"
free : "Free_cogs"
VAR
BYTE sensorvar[noparse][[/noparse] 8]
word leftcase[noparse][[/noparse] 16], rightcase[noparse][[/noparse] 16]
LONG encoderstack[noparse][[/noparse] 4]
pub turnsetup | enc_old, delta, _freecogs, i, distance, index, x ' runs stand-alone
bs2.start(31,30)
sensor.init(@sensorvar)
bs2.debug_str(string("Starting", cr))
repeat
bs2.debug_str(string(cr,"Range Left: "))
bs2.debug_dec(sensorvar[noparse][[/noparse] _Range_Left])
bs2.debug_str(string(cr, "Range Front: "))
bs2.debug_dec(sensorvar[noparse][[/noparse] _Range_Front])
bs2.debug_str(string(cr, "Range Right: "))
bs2.debug_dec(sensorvar[noparse][[/noparse] _Range_Right])
bs2.debug_str(string(cr, "Bump Left: "))
bs2.debug_dec(sensorvar[noparse][[/noparse] _Bump_Left])
bs2.debug_str(string(cr, "Bump Right: "))
bs2.debug_dec(sensorvar[noparse][[/noparse] _Bump_Right])
bs2.debug_str(string(cr, "____________", cr, cr))
waitcnt(cnt + 80_000_000)
var
long sensor, Stack[noparse][[/noparse] 25]
pub init(_array)
dira[noparse][[/noparse] 7..14]~
sensor := _array
cognew(sense, @stack)
repeat
pub sense
repeat
long[noparse][[/noparse] @sensor][noparse][[/noparse] _Range_Left] := INA[noparse][[/noparse] RF_Left]
long[noparse][[/noparse] @sensor][noparse][[/noparse] _Range_Front] := INA[noparse][[/noparse] RF_Front]
long[noparse][[/noparse] @sensor][noparse][[/noparse] _Range_Right] := INA[noparse][[/noparse] RF_Right]
long[noparse][[/noparse] @sensor][noparse][[/noparse] _Range_compare] := INA[noparse][[/noparse] RF_Compare]
long[noparse][[/noparse] @sensor][noparse][[/noparse] _Bump_Left] := INA[noparse][[/noparse] Bump_Left]
long[noparse][[/noparse] @sensor][noparse][[/noparse] _Bump_Right] := INA[noparse][[/noparse] Bump_Right]
long[noparse][[/noparse] @sensor][noparse][[/noparse] _UVtron] := INA[noparse][[/noparse] UVtron]
obj
bs2 : "Bs2_functions"
var
long sensor, Stack[noparse][[/noparse]25]
byte sensorvar[noparse][[/noparse]8]
pub start
bs2.start(31,30)
repeat
bs2.debug_dec(sensorvar[noparse][[/noparse]_Range_Left])
bs2.debug_dec(sensorvar[noparse][[/noparse]_Range_Front])
bs2.debug_dec(sensorvar[noparse][[/noparse]_Range_Right])
bs2.debug_dec(sensorvar[noparse][[/noparse]_Bump_Left])
bs2.debug_dec(sensorvar[noparse][[/noparse]_Bump_Right])
pub init(_array)
dira[noparse][[/noparse]7..14]~
sensor := _array
repeat
pub sense
repeat
sensorvar[noparse][[/noparse]_Range_Left] := INA[noparse][[/noparse]RF_Left]
sensorvar[noparse][[/noparse]_Range_Front] := INA[noparse][[/noparse]RF_Front]
sensorvar[noparse][[/noparse]_Range_Right] := INA[noparse][[/noparse]RF_Right]
sensorvar[noparse][[/noparse]_Range_compare] := INA[noparse][[/noparse]RF_Compare]
sensorvar[noparse][[/noparse]_Bump_Left] := INA[noparse][[/noparse]Bump_Left]
sensorvar[noparse][[/noparse]_Bump_Right] := INA[noparse][[/noparse]Bump_Right]
sensorvar[noparse][[/noparse]_UVtron] := INA[noparse][[/noparse]UVtron]
Thanks!
~~Brian
also when i removed the pointer symbol (@) from [noparse][[/noparse] @sensor] i was able to receive the value of [noparse][[/noparse] _range_left] but nothing else.
EDIT: all fixed. since i declared sensorvar[noparse][[/noparse] 8] as an array of BYTES, when i wrote to LONG[noparse][[/noparse]sensor][noparse][[/noparse]_range_left] it was overwriting everything.
