pwmpal
·Im using the pwmpal to output a variable pulsewidth at a steady frequency cotrolled by a pot. It works but when i scoped the signal i noticed that the pwmpal does not put out a pulse during the period of time that the stamp is comunicating with it, so the result is a glitch in the output at a frequency equal to the amount of time it takes the stamp to execute the program. So· is this unavoidable or is it all in the programing.
There are two ways to set up PWM, hardware and software, I am taking a guess you are using software control and not hardware control. If you are I would suggest using the hardware control pwm output feature. Not sure if they use glitch free phase correct pwm or what frequencies you are working with either, that could give a clue as to what the problem might be.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
