Ram checksum error
I have 2 identical boards running a lcd with other stuff.· I had a mcp3208 blow up on me which took the prop down somehow.· Anyway after replacing the prop and 3208 and trying to program the chip it comes back with (ram checksum error).· I have swapped eeproms and even programmed eeproms sucessfully in my other project board.· After removing part of the program, it loaded sucessfully.· If I try to run the programmed eeprom in the bad board it does some funny things with the program.· Any ideas why?· Could part of the ram be bad from the factory?· ·
Paul Baker
