functions and pin parameters in SX/B — Parallax Forums
DunnseptDunnsept Posts: 115
edited 2007-03-30 20:42 in General Discussion
Hey guys, haven't posted in a long time, so .. here goes:
I would like to write a function that would have a PIN as a parameter and would return a word.
The assembler is complaining that my parameter is not a hardware pin
so, how do I pass a pin as a parameter?· This is going to be for controlling DS2760's so I would much rather
have functions than have to duplicate code.
code is something like
mash var RA.0
check_temp func 1
main:
     hlt_temp = check_temp mash
 goto main
check_temp:
     which_ds = __param1
   'whole bunch o 1wire stuff
   return theTemp
but the compiler complains on the __param1 line that "bit is not a hardware pin"
thanks!
stand back! I have a slide rule and I know how to use it!
  • JonnyMacJonnyMac Posts: 9,800
    edited 2007-03-30 18:56
    You can't pass a pin (e.g., RA.0) as a parameter. If you're using 1-Wire, why wouldn't you have just one buss and identify the units by their serial number?
  • DunnseptDunnsept Posts: 115
    edited 2007-03-30 19:03
    yea.. I was just trying to figure out other ways to do this. I've got plenty of pins open and kinda thought instead of having to deal with figuring out the serials I would just put them on different pins and call it good.
    currently using an SX tech board, can I just go from, say RB.0 to data pin on one DS2760 and then jumper over to data pin on other DS2760?
    edited 2007-03-30 19:41
    Yes. You'll put a 4.7K pull-up on RA.0 for the buss. All of your 1-Wire devices connect to this. To be candid, I find 1-Wire more trouble than it's worth and tend to choose I2C parts -- IMHO it's easier to give up an additional pin than to implement all the interfacing code to deal with the 1W serial numbers. But if your part is unique to 1W, you just have to go the code route.
    edited 2007-03-30 20:02
    well, I'm working with the DS2760 kits from parallax.. so all I have to do is hookup vdd, vss and data.. good to go. just trying to consolidate code so I can run 2 of these, plus 3 displays..running out of space already
    thanks
    edited 2007-03-30 20:23
    I'm a bit packed up now, but I'll get one of those out and see what I can come up in the next couple weeks.
    dont worry about it.. I'll get it eventually. Just finally getting back into programming these things (sx) after a hiatus. gotta get back into the swing of things.
    thanks for the offer
