Hold an output signal high — Parallax Forums
William01William01 Posts: 2
edited 2007-03-30 19:09 in BASIC Stamp
This seems really simple, and I've tried searching the forum (as well as google and the programming manual) but couldn't find it.
Is it possible to hold an output signal high while the stamp carries out other instructions, and then lower it later on when needed?
If so, how is this done?
  • stamptrolstamptrol Posts: 1,731
    edited 2007-03-30 19:00
    Assume you're talking about pin 1, for instance.
    HIGH 1 will turn it on
    It will stay on until later in the program when you say
    LOW 1
    As long as your other programming doesn't overwrite these instructions, they will behave correctly.
    Cheers,
    Tom Sisk
    http://www.siskconsult.com
  • William01William01 Posts: 2
    Awesome. Thanks, Tom!
