ping proto board question
could I connect· the ping to the servo location like on the BOE board and still use two servos do i need a 470 om between ping and prop? what is the difference between Vin and 5 v? and would my robot move slower if it is set to 5V instead of Vin?
The servos operate on 4.8V to about 7.2V. It's better to run the servos off Vin as long as it's 7.2V or less since they can draw an ampere or more and most regulators can't put out that much (particularly without a significant heatsink).
If I understand correctly, a 4.7K resistor is suggested for a Servo, and a 470 ohm is suggested for a PING.
Brian Meade
"They who dream by day are cognizant of many things which escape those who dream only by night" - Edgar Poe
Brian Meade
