Hello all,
I'm was trying to do a search for a BS2 schematic. I have seen them on this forum; some showed the BS2 hooked up to a DB9 connector as well as a USB. Can someone tell me wherethese are, or how to get the fricken search to work?
Thanks billions....
For the BS2 it's: www.parallax.com/detail.asp?product_id=BS2-IC.
http://www.parallax.com/dl/docs/prod/boards/BOERevC.pdf
Where are you Searching?
I found these over at www.parallax.com
Find the product you want and they ordinarily have the schematics (as a PDF) toward the bottom of the page.
If you’re referring to the Forum Search (you mentioned seeing something on the Forum) it doesn’t work very well. But we have provided a better one at the first link below. This is a sticky thread in the Forum Support area (Support For Using This Forum). In the meantime, if you’re looking for what I think you are, try the second link, which is the BS2-OEM Lite Schematics in the Completed Projects Forum. Take care.
http://forums.parallax.com/showthread.php?p=562370
http://forums.parallax.com/showthread.php?p=567989
