Propeller and Pullup resistors?
Does the Propeller have built in pullup resistors like in the SX chips.· I use the pullups in the sx to avoid these extra components on the board.· Are they present in the Propeller?
It's Only A Stupid Question If You Have Not Googled It First!!
Seriously though, NO (as far as I know). Pull-ups can be useful but unless they are implemented well they can be a nuisance. If they are non-programmable pull-ups then you lose the high-impedance input that is necessary at times plus it is harder to make the device really low-power as any inputs could be drawing current. If they are programmable then where do you stop as you can have several registers dedicated to this function alone and there will still be users who will be unhappy about how it is implemented.
Have you heard about USERs? They are a special device that is a User Selectable External Resistor
*Peter*
*Peter*
