Energy Efficient Supplies — Parallax Forums
T ChapT Chap Posts: 4,260
edited 2007-04-15 08:26 in General Discussion
Some thinking out loud on an EE supply design.
I have around 8 boards that have both 5vdc and 3.3VDC regulators on them. There is also a DC motor driver board that needs to provide 32-38 VDC at 3-4 amps when the motor is used. When the motor is not used, it does not require holding torque, the encoder will detect any error and pull it back in place if required.
I am looking for the most energy efficient way to supply the system, I am thinking 1.5 amps will be the ballpark for the logic boards when I am done, and 7-10VDC will power all the regulators. I intend to use a toroidal for the motors if I can find one beefy enough, 24VAC will get me the required unregulated ~37DC. The question is, will using another smaller 6VAC transformer be the most economical to produce the ~10VDC for the logic supply? Wouln't regulating down the 24VAC burn a lot more juice that just adding a smaller transformer?
Looking at the Amveco Toroidals, they claim "low no-load current and very low no-load losses." I had considered using a really large cap on the motor driver, and switching out the large Xformer when not in use(no idea yet on where or how to switch it. The big cap just needs to provide a few milliseconds of power if the motor is required to do some work(motor is off more than on).
There could be a Prop ADC monitoring the cap, if it drops below some usable value, it kicks the 24VAC>Bridge rect back in, fills back up the cap and shuts off again. This idea is strictly to reduce power consumption. If the transformers really didn't pull anything when idle, maybe not even bother with the switching idea. The logic supply AC source is the real question.
Any sugggestions on these ideas?
Post Edited (TChapman) : 3/28/2007 3:53:46 AM GMT
640 x 640 - 172K
  • QuattroRS4QuattroRS4 Posts: 916
    edited 2007-03-28 03:59
    I have built switching regulator based power supplies with LT1074 (by linear technology) with approx 45VDC unregulated input - and they have worked out very well - very little heat - only when really pushed - I tend to use dual switched mode LT1074's when incorporating inductive and noisy loads - one for logic - set to approx 8v - through 2 linear regs 5v and 3.3v. Similar designs have been running 24/7.
    I will have a look at best rated trafo's ...
    In the meantime - I have attached a datasheet on the LT1074
    'Necessity is the mother of invention'
  • T ChapT Chap Posts: 4,260
    edited 2007-03-28 04:07
    You are saying run one trafo>LT1074>5V(x8)>3v3(x8) as in my case?
    I remember some cheap 24VAC CT 4amp transformers I got from Allelectronics recently(photo), they were pretty warm with no load, then again probably not very efficient.
    I like the asthetic of the blue Amveco, but the largest PCB mount they show is 22VAC, 2.28 amps, maybe could be sufficient for the task.
    Post Edited (TChapman) : 3/28/2007 4:21:33 AM GMT
    200 x 200 - 8K
    edited 2007-03-28 04:11
    Just spoke to an Audio Guru guy here - he has years of experience with Amplifier designs and Amveco toroidals are right up there with Plitrons -
    www.plitron.com/
    edited 2007-03-28 04:21
    Not (x 8) - missed that - but if you see the LT1074 data sheet has a LT1076-5 listed which provides 5v@2amps - this is a fixed output regulator version.
    or use 2 x lt1074's (1 for 3.3v the other for 5v ) as the range is from 2.5VDC to 60VDC with high output current capabilities as per datasheet.
    Option1 - Use 1xLT1076-5 and 1xLT1074 (set to 3.3v)
    Option2 - Use 2xLT1074 - (1 for 5V) the other (3.3v)..
    these are all short circuit protected.
    ·- the 7pin package has Current limiting option - so you can limit the Imax out from the reg - so you don't cook the trafo..
    Post Edited (QuattroRS4) : 3/28/2007 4:26:10 AM GMT
    edited 2007-03-28 04:30
    Thanks for the info Quattro
    edited 2007-03-28 04:38
    TC - another option is the likes of the following - dedicated to your logic - off the shelf complete unit -
    A complete switched mode power supply with multiple outputs ...
    look at VLT40-3203 in the datasheet
    Post Edited (QuattroRS4) : 3/28/2007 4:43:18 AM GMT
    edited 2007-03-28 08:09
    I like that idea of the self contained, after some study, switching seems the way to go for low heat, low waste. Lots of real estate consumed though.
    www.allelectronics.com/cgi-bin/item/PS-115/480/130_WATT_SWITCHING_POWER_SUPPLY_.html
    Something similar above, 5V/5A, 24V/5A for $37. I can test the motors on the 24V rail and check the performance(BLDC). Since I already have the 5VLDOs>3v3LDOS on the boards, I may be able to get away with feeding them the 5V switched supply. I need to check where the drop out is, but I would think you could put 5 in and still get 5 out. That would be very effecient if it worked. This is new territory for me so forgive the ignorance on the subject. The real issue may be if there is no load on the 24V, will the supply stay happy.
    It's nice that All electronices is <10 miles away, I know the guys there pretty well, I'll just plug it in on the counter and test it out.
    edited 2007-03-28 14:12
    TC - Quite a few of the more sophisticated PSU's will allow a no load (or minimum load). Use the PSU 5v directly for 5v logic and also use it to supply the 3.3v regulators. Or use one of the LT1074 for 3.3v.
    edited 2007-03-31 03:18
    I am going to use the LT1074 for the 5v rail and let it feed the 3.3's. The linear unregulated can be anywhere around 36V. There is one issue to resolve, I like the compactness of the blue Amveco toroidials shown in the initial post. The problem is those units only go to 2.2 amps in the largest size. There are some unknown variables, such as I haven't tested the system yet that it is going to power. There is the possibility that with some gearing, 2.2 amps will be fine. If not, the choices are to go with the larger Amveco transformer, but it is an exposed version, not encapsulated. It requires the rubber gaskets, and bolt through center mounting etc, just not a nice tidy PCB mount like the one shown. The larger transformers are also much more expensive to get around 4 amps, over $125, I can use two of the 2.2 amps and still save money.
    What about I make a board that can be stacked with board offsets, build one that outputs 36V with the LT 1024 on it, and see how it goes with the motor. If I can't gear it enough to get the work done, then stack another 2.2 amp transformer>rectifier>cap on top of the other board and parallel the outputs?
    Post Edited (TChapman) : 3/31/2007 7:50:46 AM GMT
    edited 2007-04-01 00:27
    TC - Not sure if specs. allow + to + and - to - parallel configuration - but you could just tie the grounds together.
    edited 2007-04-01 03:58
    Thanks for the suggestion. I was only looking at combining the unregulated outputs post rectifier. Here is the idea below, just using the data sheet schematic for the LT1076 5V switching regulator. The unregulated out will feed the motor driver which will sit around 30 - 34V, the transformer is two 22VAC paralleled at a total of 2.2 amps.
    Post Edited (TChapman) : 4/1/2007 4:19:51 AM GMT
    1147 x 698 - 100K
    990 x 696 - 131K
    edited 2007-04-01 04:51
    TC,
    That is looking sweet !
  • OzStampOzStamp Posts: 377
    Hi Chapman.
    Great looking schematic and board ..
    The only comment I have is that the track with the 5VDC on it seems a little narrow..
    It of course depends on how much current you draw from this PSU but I would receommend
    you fatten the tracks slightly.
    Rgds
    Ronald Nollet Australia
