i need some basic tutorials on each of the commands
hello all:
first of all let me introduce myself, i am not a puter guru, and have
no programming experience at all, up till a couple of weeks ago when i
purchased my bs2 boe kit.
i am also amazed at what i have been able to do with some work, reading and research.... but
i need some basic tutorials on each of the commands, the book that came with it is pretty good, but i need some more excersizes if you will.
such as more than one example of how each command ·works.
sort of like the way they taught me to read,,, you know the drill
run tip run
run run tip
tip run run
[noparse]:)[/noparse]
most of what i have found assumes you know at least something to start with,
i feel i am in chinese class having never heard, seen or even knew a chinaman existed.
any reference material, books or simplistic stuff available?
thouhts or idea's are welcome
thank you
bob g
Post Edited By Moderator (Chris Savage (Parallax)) : 3/27/2007 10:34:36 PM GMT
run tip run
run run tip
tip run run
thank you
bob g
Mike is steering you in the right direction.·"What's a Microcontroller" (WAM) ·is the intended starting point for our·Stamps in Class educational series, and we reccomend that you also keep the·BASIC Stamp Manual handy for more complete examples of how each command works.· If it did not come with your kit you can download it for free here:
http://www.parallax.com/detail.asp?product_id=27218
The example programs in the BASIC Stamp Manual are the same ones in the BASIC STamp Editor Help, and the actual .bs2 files were included with the installation.· Try running and modifying those.
And you may always post questions here, big or small, sincere learners who are willing to do the work, reading and research are always welcome.· If you are working primarily from WAM, the Stamps in Class forum might be the best resource since the author checks in there frequently.
-Stephanie Lindsay,
Editor, Parallax Inc.
i have the "whats a microcontroller"
just hoping i could find something a bit more indepth, or with more examples.
perhaps i need to give the book more of a chance.
old dog new tricks and all that
thanks
bob g
"grumpy old farts unite"
The StampWorks is great.· I suggest you look at that also.
Once you finish that, I would suggest looking at the Nuts & Volts articles and pick ones of interest to you.
That is how I taught myself.· Good luck.· You will become a Stamp-a-holic in no time, like myself.·
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Help .... Contents .... to be a really big, and quick, help. It has examples of things you may have never used or have forgotten.
when i get to a more specific problem or question i will post it and see if perhaps
you fine folks can walk me thru it.
so far things are working surprisingly well, seems like each time i work with the code,
i get a cleaner way of doing it using the commands i have learned.
i am sure in time i will learn the more sophisticated methods.
but there is something to be said for doing things simple if possible.
thanks
bob g
