Acceleration - mathematics and equipment advice
Hello all,
I'm currently studying at University, and need some advice.
I am looking to measure the acceleration of a large (7 tonne) unit during a drop test (of around 10mm), and I've been told the acceleration will be less than 1g (9.81 m/s^2). However I'm not sure what the best equipment would be to measure this acceleration (very limited knowledge of accelerometers etc).
Also, I am interested in the mathematics behind this, so if anyone can point me in the right direction of the calculations required it would be much appreciated.
Thanks in advance.
Thanks in advance.
http://www.parallax.com/detail.asp?product_id=28026
A possibility to send the data wirelessly as it falls using Xbee's or other RF units.
As far as the math... what were you looking for? Anything in freefall (on earth) will fall at a rate of 1g (9.8m/s), but drag and other factors will cause it to be less.
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
The rate would be affected (mostly by air resistance) if you were dropping 7 tons of unrolled aluminum foil, but a 7-ton cube of aluminum would not manifest easily-measured drag/etc over a 10mm distance from an initial resting state.
So, I'm not sure whether you were assigned a simple problem (ignore drag/etc), in which case Martin's observation that the rate is more or less a known constant is good enough, or whether you were given a seriously difficult problem, in which case much more would have to be known about your drop test setup and experimental requirements. Like Martin said, "What were you looking for?"
PAR
-Martin
Could you physically measure the changing distance to the floor? Perhaps a piece of conductive foam between two plates, placed under the unit. As the unit falls it crushes the foam changing the resistance between the two plates.
The 2G acceleometers that Parallax sells are well documented and cheap. Find them (sensor, documentation and circuit diagrams) in the store-- In 2 hours you'll have a working circuit that demonstrates what Galileo proved in the 16th century. Oh, if you must drop something, drop a 7 ounce weight scaled proprtionately and measure that.
Not blaming you, but this sounds just plain silly to me.
Post Edited (LSB) : 3/29/2007 7:16:01 AM GMT
I've got some more information which will clear up a few issues.
The drop test is a requirement of an IEC standard for transportation·of a 7 tonne transformer which will be housed in a (new)·protective container (2m high by 2.5m wide). To satisfy this standard, the unit must withstand a freefall of 10mm. The test cannot be carried out more than two times, therefore the first·drop will be used to assess the acceleration, and the second for the test (i.e. change height of drop test so that unit experiences free fall (or close to it). The height cannot be higher than 15mm to safeguard the transformer.
The company are planning to use a crane to hoist the container, then release the brake to drop it. I think this was the crucial piece of information that I overlooked before (and should of mentioned in my original post). I think the friction from the cable/crane etc is the reason the acceleration will be lower than 9.81 ms^2. They are also interested in the mathematics behind my calculations during both tests.
I will also be considering other options that may be better to conduct the test (instead of crane etc).
Hope this extra info has cleared up a few points. I will check the accelerometers that you have suggested.
Thanks again.
The documentation has to show that the acceleration was at least gravity without being reduced by the crane or other influences.
Get accelerometers (definitely more than one) for the first test and hook them up to a good analog recorder or fast digital recorder. I think you'll need to have a quick release shackle on the lifting point in order to get close to the free-fall case. Even though its only a 7 tonne load, you may need a hydraulically actuated shackle or an explosive bolt type to get quick action.
If you're lucky you won't have to bump the unit too many times!
I assume you'll do a bunch of electrical tests after the drop to show up any problems before its delivered to site?
Cheers
Tom Sisk
http://www.siskconsult.com
I use this as a payload in my rocket to determin acceleration. I use high G accelrometers to withstand the high Gs caused by rocket flight.
What I think you need is a distance sensor vrs. time stamp, that outputs a voltage.·Use a fast 8 bit ADC with a narrow reference voltage range to improve the resolution.·Save the data to the processors internal ram, maybe using a 16 variable index array. Once the index is done, put the program to sleep. (or some other method, that doesn't destroy the·data variables·collected)
Post Edited (Capt. Quirk) : 3/31/2007 8:13:52 AM GMT
Have a nice day,
Ed
Second, let me suggest there are other means of gathering data that may indirectly answer your need (some or none may apply). Perhaps it may be possible to measure the air displaced under the unit as it drops, or the vacuum created in a cylinder above. A lever, properly positioned, would scale the drop and allow for use of high speed photography to verify time/ distance measurements. Similarly, a 10mm pulley married to a 1mm pulley or a 100mm pulley would scale the drop by a factor of +/- 10.
I think too that the rate of fall is governed by the laws of physics, measuring impact force as “instantaneous weight at impact” might satisfy your requirement. The deformity of a block of metal of known hardness might then describe the impact force sufficiently for your needs. If its posible to engineer some void in the floor beneath then lasers or ultrasound ould be employed without crushing the equipment.
The problem is an interesting one—the answers are known, only the means is left to discover. I'd love to see video of your "final"
