Looking for some advice on getting a soldering iron
XNOR
I think I've finally had it with my $4 soldering iron.
I'm looking for some advice on getting a better iron.
Since I don't do much soldering (I'm an amateur and mostly use solderless breadboards),
I would rather not spend a lot of money on something I won't use too often.
Of course, I know that you get what you pay for.
So, I'm looking for some middle ground where the soldering iron is inexpensive,
but not completely frustrating to use.
The problem I'm having is that the tip seems to be hot in some places and cold in other places.
So, sometimes the solder flows very nicely, and sometimes not at all.
I've tried replacing the tips, but that only helps for about a minute (if at all).
I've found some soldering irons that look promising, but I don't really know:
www.elexp.com/sdr_5202.htm
www.elexp.com/sdr_5258.htm
www.elexp.com/sdr_23lk.htm
Do any of these look good?
Does anyone have any other suggestions?
Thanks for any help.
It has served me well for a $40 iron.
I use the 0.032 tips.
Bean.
"Educate your children to self-control, to the habit of holding passion and prejudice and evil tendencies subject to an upright and reasoning will, and you have done much to abolish misery from their future and crimes from society"
Benjamin Franklin
www.hittconsulting.com
www.antex.co.uk/
they have listed a few US suppliers..
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 3/28/2007 4:53:23 AM GMT
Shawn Lowe
My last words shall be - "NOT YET!!!"
Paul Baker
On the other hand, I see the Weller WLC100 (that Bean mentioned) get recommended so often on so many message boards that I have to believe it's probably a great choice.
One other place you might want to check is Circuit Specialists. I see them get good recommendations frequently for their own line of soldering equipment.
- Rick
"Tip tinning" is keeping a bit of solder on the hot tip, as well as while it's heating up and once you unplug and cool it, too.· Don't let them go "dry," the result is corrosion.
Damp sponge = saturate it and then wring all of the water out.·
Before applying the iron/tip to your connection, wipe it off (nice and shiny), touch it with the solder, then apply it to the joint, flash some more solder to the hot joint, remove the tip from the joint and park the iron.· The heating and all should be a quick operation, one shouldn't tarry there.
Update -- And don't ever touch the tip to plastic, rubber, anything like that -- the result is "organic contamination", bad news.
A Kester Ultrapure Tip Tinner helps prolong tip life greatly.
Post Edited (PJ Allen) : 3/28/2007 1:04:29 PM GMT
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning.
Microsoft: "You've got questions. We've got dancing paper clips."
This is a very nice soldering station you can use different tips also have surface mount IC's tips
i have one of these units and i am very very happy with it
Temp controls·are the·temp set and temp read out which are the best thing about it i think
When you order it talk Shawn he is very help full also ask about th Solder Roll Holder that is also very nice
www.howardelectronics.com/xytronic/137ESD.html.........·
·This is a very nice tip 1.6mm barrel one
·You will have about··as much fun as these two are having·
I think that you be very happy with it I know that i am
I hope this help you
··Thanks for any·
Sam
Bean.
Benjamin Franklin
I'll try the "tip tinning" method mentioned by PJ Allen and Bean,
to see if that will solve by problems.
If not, it sounds like the Weller WLC100 should be a safe bet.
Thanks again for the help.
I got a Xytronic 379 from howard (see above) for $49. great company no matter which iron you buy. they really know their stuff AND they have an upgrade guarantee. If you dont like the iron ship it back for credit towards a new one. they also have some used stuff cheap.
just did some of my first SMD soldering with mine tonight. worked great.
and I can tell you to follow bean's & PJ's advice on tinning the tip. I forgot to do mine and the tip was black (oxidized) and would not make a nice joint. time for a tip replacement
stand back! I have a slide rule and I know how to use it!
Thanks!
--Bill
You are what you write.
Post Edited (Logicalsifter) : 4/7/2007 1:51:41 AM GMT
