Using DJNZ with Array Element — Parallax Forums
JDOhioJDOhio Posts: 72
edited 2007-03-28 02:06 in General Discussion
When I use DJNZ with an array element, the compiler throws an error.
MyArray  VAR  BYTE(2)
First    VAR  MyArray(0)
Second   VAR  MyArray(1)
DJNZ First,ALabel
INC Second
ALabel:
The compiler error is BYTE VARIABLE EXPECTED, and it is on the DJNZ line.
Any ideas?
Joe
  • JonnyMacJonnyMac Posts: 9,797
    edited 2007-03-27 02:17
    DNJZ expands directly to its Assembly counterpart so it's expecting a byte, not an array element that actually exists in another page. I think can get there from here by doing this:
      DEC first
      IF Z = 0 THEN A_Label
      INC second
    This allows the compiler to point to the array and your variable to be decremented. The Z flag is tested manually.
  • JDOhioJDOhio Posts: 72
    edited 2007-03-27 23:55
    Thanks! I was thinking the same thing. I asked the forum because the help file indicated that DJNZ would operate on byte array elements.
    Joe
    edited 2007-03-28 00:24
    You're right -- it says that. I'll check with the compiler engineer to see if we need to fix the help file or update the compiler!
    Cool. Either way is good with me. If you update the compiler, it will probably compile to your previous post which may not have much benefit except the S/X BASIC looks cleaner.
    Joe
