Ambient light RGB Signal
Hi, i want to make a controler waht reads the color of an RGB video signal from the left and right side of a screen.
and then drives some cold cathode light behinde my TV.
Can the propeller do such a thing
regards Anubisbot
regards Anubisbot
I don't know exactly if the Pchip, could digitalize only one line of video...it depends of how many samples per line do you want ?
Do you mean only one line ?, perhaps some flash A/D converter, could help you a bit for that.
Why not RGB LEDs behind the TV ?
Regards.
Alberto.
If not, you'll have to decode and integrate by hand.
And yes like the Phillips TV....
right now i try to figure out how the rbg signal works and hiow it can be read out ...
Anubisbot
