Count
How can I use the COUNT command to measure frequency with the schmitt trigger? I am trying to input sound from a violin into a microphone and then have the signal pass through the schmitt trigger into the basic stamp. Then somehow the basic stamp could determine the frequency with count commands. Does anyone know how I can use the count commands to measure frequency? I have A BS2 module.
The COUNT command returns the number of transitions in a given duration. So for example, if you set that duration to 1 second, the returned number will be your frequency (cycles per second). Take care.
