Got my kit...
Howdy,
Got my kit on Friday, hooked it up and ran a few demos, everything works great...
Then I started reading the book and I still am reading it...
Great work, it explains everything just on my level, not to easy neither to hard...
I just got to finish up my 24x24 LED sign controlled by my Replica I (A 6502 based Apple I clone) so I can start learning the Propeller.
Great work Andre'...
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Experience level:
/Bamse
Here's the link. Its about 1/2 way down.
http://forums.parallax.com/showthread.php?p=636887
Andre'
I'm actually making it easy for me, the 8x8 Led segments are pre made and I'm using nine MAX7219 to drive them...
So far, I just mounted the LED Segments...
Experience level:
/Bamse
Post Edited (Bamse) : 3/26/2007 4:44:55 AM GMT
I love the larger display. Have you tested the LED's to make sure they are bright enough? My 16x16 display will have to use premade displays like this because they are simply not bright enough (e.g. MCD) - although they are ok for testing. What made you choose 24x24 and not another size? Currious thats all about the design. I have also Googled and seen 16x16 single·piece·LED displays (that I may use). I·currently·am using an SX52 for all of it's I/O. However, the MAX7219 is a good choice. I have never been able (like many people) to "Cascade" them. Let me know how you do this. Lot's of coding for this one but the Hydra has the variable and programming space too.· Does the Hydra (propeller) use interupts (as it was pretty much mandatory for my display) - although if you are using MAX7219 it may not be needed - cascading is your biggest issue (almost no documentation on it) - read the posts about this chip. I have not been able to find any "specific" coding on how to do this other than "general" info on it.
Great idea - I can't wait to see your progress!
I'm getting worried about the problem daisy chaining the MAX 7219, I didn't try it on my breadboard...
Just read the documentation and assumed that the data out would just stream the bits through with a 16 bit delay...
By the way, the MAX 7219 were free samples, you got to love Maxim-IC. They sent me two a month so it took a while to get them though...
The brightness is fine even with 2/3 of full brightness, the MAX 7219 is doing a fine job there.
I'm not using the Hydra for power, with a total of 3 Amps (all LED's on full brightness) something would probably break...
Just to keep this thread Hydra-related...
A really cool thing would be to display things like speed, current gear, fuel, life, time, credits or scoring separate on this display.
Or a radar for a flight simulator, music bars, road signs, compass, directions, etc...
I can think of a few things...
Experience level:
/Bamse
Andre'
I just·ordered 10 8x8 LED displays for $7 + $10 shipping on Ebay - should be here next week I guess. I would like to use something that can handle more LED's than the MAX7219 (as I have never been able to figure out how to cascade them together). I have 3-4 of the MAX7219 now (2 were free samples from Maxim). I thought I read about a MAX chip that can handle 128 LEDs (but 256 or more would be better).
Any ideas?
Try searching on this page, http://www.maxim-ic.com/Display.cfm
MAX6955 seem to be able to drive up to 128 LEDs, maybe I should try get a sample...
I need to get into Surface mounted ICs sooner or later...
I'm biased to Maxim since I gotten so many free samples over the year, but Texas Instuments does have LED drivers as well...
MAX6955, http://www.maxim-ic.com/quick_view2.cfm/qv_pk/3540
Experience level:
/Bamse
Do you have an idea on the TI chips to use?
It took me forever (about 5 months) to get the 10 MAX7219 I needed, keep ordering them and you get like two per month or so...
I think I had to re-order over and over again but it worked...
I know, I'm a cheap bastard...
Experience level:
/Bamse
Scaling up to 16x16 or beyond has been a back burner project for sometime. 24x24 is a lot more ambitious. Because of the one byte microprocessor, it would be easiest to run three 8 bit tall by 24 bit wide lines and have them multiplex [noparse][[/noparse]cycle 1, 2, 3]. Data in put would alternate between the the 3 rows at a speed faster than the eye could see.
Also, having a counter set from 1 to 24 would move to the next column
So it might go Row 1 column 1; Row 2 column 1; Row 3 column 1; Row 1 column 2; and so on.
I am not sure if the MAX7219 would fit into that scheme. I have to read the PDF. I wouldl probably use something like the UNL2803s [noparse][[/noparse]but with a Chip Select feature] for the three ROWs and some kind of adjustible counter IC for the columns.
Andre is right. You cannot power an 8x8 directly from the microprocessor without some dim output or stress. So you need to have each row and column controlled by some kind of power switching [noparse][[/noparse]either included in the ICs or as a discrete transistor]
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
See my postings in the Replica Forum...
http://www.brielcomputers.com/phpBB2/viewtopic.php?p=936#936
Let's start another thread in the Sandbox forum if we want to continue discuss the MAX7219...
And Yes, sooner or later this display will be hooked up to the Hydra...
Experience level:
/Bamse
Have you seen my recent posting as of last night on cascading 2 or more MAX7219 ICs to a BS2. I am working on porting this to an SX28 too.
http://forums.parallax.com/showthread.php?p=636061
At the bottom is a schematic and BS2 code.
It's encouraging to see work on the MAX7219 as there seems to be little information on the web on working with it in Non-Decode mode (LED dotmatrix - 64 LEDs).
Start a thread if you wish and I will join in as needed.
Good job on the 6522 / Replica I interface too.
